.NET micro Framework device
24 replies to this topic
#21 CW2
Posted 26 August 2010 - 03:05 PM
For my point of view, OneWire issue is not related to processor speed. It's more related to C# latency inducted. So, the solution, like other vendors, is to provide a OneWire feature in native code and a library in C# to use it.
The processor itself is surely fast enough for 1-Wire, at this time the problem is with native (C++) code generated by GCC, but it works. Please note there are several abstraction layers in TinyCLR, to handle hardware platforms differences - typical architecture tradeoffs apply here. There is always possibility to write one long asm { ... } block (or whatever is the compiler's syntax).
I use onewire with a AVR 328p at 8 Mhz !!!
I use AT89LP4052 Posted Image
#22 Szymon
Szymon
  • 108 posts
  • LocationPoland, Krakow
Posted 26 August 2010 - 06:07 PM
It works on Arduino so it would be weird if Netduino's much superior CPU couldn't handle it :-)
#23 Chris Walker
Posted 26 August 2010 - 06:11 PM
Based on what you folks are saying, I don't see any reason why we couldn't integrate a native driver for OneWire into the core Netduino firmware. CW2 is working on one--and we've offered to open up any capabilities necessary to do that (open drain configs, etc.)
#24 segu
segu
  • 31 posts
  • LocationLima - Peru
Posted 27 August 2010 - 03:58 AM
At least OneUser (me) will be VERY VERY happy ;). By the way more IO be good, always there is a project that needs more pins than available :huh:
#25 Coding Smackdown
Coding Smackdown
  • 78 posts
  • LocationLewisville, TX USA
Posted 28 August 2010 - 03:47 PM
I'd be another user that would be very happy with One Wire support baked in to the firmware. There are a lot of cool devices out there that use the One Wire protocol. Since they can all be accessed over the same one wire interface it sure helps out a lot when you have a bunch of devices you want to talk with but don't have a lot of GPIO pins. I'd even be interested in seeing both master and slave type of capabilities, so the Netduino could control device and be controlled by a PC or other device. If you need help, I'm willing to lend a hand.
http://diybrewery.com
