.NET micro Framework device
24 replies to this topic
#1 pascal06
pascal06
  • 95 posts
  • LocationFrance
Posted 24 August 2010 - 12:26 PM
Hello Netduino community, I search for a more powered device needed for a new project (IPv6 network project), I would like to use multiple netduino (when it will be ethernet ready), and one of that device, Here is the needed features : - .NET micro framework ready - 1MB of flash or more, same for RAM - Firmware open source, because I need to write some native code for performance and low level network features. - Ethernet, enc28j60 prefered, because of lwIP compatibility I found a lot of devices, but I don't know if the firmware are open source or not :blink: Thanks in advance, Pascal
Posted 24 August 2010 - 04:35 PM
Perhaps we should build a Netduino "Ultra" with MBs of on-board RAM/FLASH and on-board Ethernet? Chris
#3 Steven Behnke
Steven Behnke
  • 70 posts
  • LocationLas Vegas, NV
Posted 24 August 2010 - 04:46 PM
Sounds like a good idea to me.
#4 Omar (OZ)
Omar (OZ)
  • 564 posts
Posted 24 August 2010 - 04:49 PM
YES! I love it. I'd buy that, Now that I have convinced my parents that this isn't stupid! I know right? Who would think such a thing. But anyways that would be awesome... built in ethernet would kick arduino's butt.
#5 pascal06
pascal06
  • 95 posts
  • LocationFrance
Posted 24 August 2010 - 05:31 PM
It would be perfect !!!! + EEPROM :rolleyes:
Escpecialy if the Ethernet is compatible with lwIP,
Pascal
#6 greg
greg
  • 169 posts
  • LocationChicago, IL
Posted 24 August 2010 - 06:06 PM
Pascal
I will admit I'd love to see a small EEPROM. The rest I don't think are really necessary (I mean the netduino already has a crapload of memory and flash compared to the arduino) not that I'd say "no" if there's more - more is (almost) always better! Onboard ethernet I think is unnecessary as long as its supported in the firmware - there are too many projects that won't use ethernet to warrant having it on the board. As long as its in firmware it can be "aftermarket".
However, if you are seriously considering an "ultra" style board I wouldn't say no to more GPIO pins. :)
#7 Steven Behnke
Steven Behnke
  • 70 posts
Posted 24 August 2010 - 06:11 PM
I believe Chris already said they are working on exposing some EEPROM along side the SD card support, but I'll let him clarify that.
#8 pascal06
pascal06
  • 95 posts
  • LocationFrance
Posted 24 August 2010 - 06:15 PM
Considering Ethernet feature is already avalaible on the ship ... Why not to have the possibily to use it ? Perhaps, to be open, just make the pins available to connect a magjack in case of you want to use it and the corresponding firmware.
Pascal
#9 Omar (OZ)
Omar (OZ)
  • 564 posts
Posted 24 August 2010 - 06:38 PM
Ultra board should be ultra! more pins and more memory isnt bad. on-board ethernet is useful any time! I say yes to all these Ideas, although best would be more I/O pins
#10 Chris Walker
Posted 24 August 2010 - 06:45 PM
On the topic of EEPROM--are you wanting actual EEPROM (read/write tons of times) or just a few KB of on-board storage for ocassional use? Chris
#11 pascal06
pascal06
  • 95 posts
  • LocationFrance
Posted 24 August 2010 - 06:58 PM
In my case, currently, it's just to have persistant information like IP address ... So just a few KB of on-board storage would be suffisant.
Pascal
#12 pascal06
pascal06
  • 95 posts
  • LocationFrance
Posted 24 August 2010 - 07:32 PM
Chris, when you say that, do you plan to use other feature than ExtendedWeakReference ?
#13 phantomtypist
phantomtypist
  • 142 posts
Posted 24 August 2010 - 08:01 PM
Definitely! I would like a Netduion version that has more memory, a few more GPIO pins, and an SD card support on the PCB.
And if it isn't too much to ask for, an ethernet port on the PCB would be nice!
Great job so far!
#14 Chris Walker
Posted 24 August 2010 - 08:09 PM
Maybe. We've left about 16KB of space for a pre-bootloader on the Netduino...and we're evaluating if we can squeeze it into 8KB and leave 8KB for data (ExtendedWeakReference or a "permanent" 8KB byte array).
Basically, what that would enable is the ability to write data directly into the Netduino's FLASH memory. We'd have to work out details--and we'd probably have to allocate it as 8KB total space. But then if we have SD shield support, that takes away much of the requirement as well.
BTW, there's a "configuration" sector on the Netduino. That's where .NET MF stores the IP/MAC settings for lwIP, etc. You may be able to sneak some data in there as well (although updating firmware will probably wipe out any data you write there).
#15 greg
greg
  • 169 posts
Posted 25 August 2010 - 12:05 AM
Chris - 1K of space is MORE than enough. For IP networking you need a minimum of 96 bits (IP address, mask and default gateway). A few more bytes available to be able to do things like save ports and such if you're trying to write a netduino server that things can connect to and you're golden. So really you only need about, oh, say 24 bytes of space for all your IP networking needs. Oh, maybe a few extra bytes so you can override your MAC address or create virtual MACs so you can give your netduino multiple IP addresses. This ignores IPv6 mind you. You need more space for that.
#16 stacyh3
stacyh3
  • 47 posts
Posted 25 August 2010 - 01:14 AM
My 2 cents, I like the idea of a variety of boards. If I need Ethernet in my project, I'd choose that one. If not, then I'd choose the base model. Some things can be done with "shields", but having them integrated is cleaner and smaller. Stacy
#17 greg
greg
  • 169 posts
Posted 25 August 2010 - 04:33 PM
Just thought of something else I'd love to see - a couple of power pins for the netduino itself. I'd like to be able to power it with LiPo batteries using a JST connector, but just a a couple of power input pins I can work with. :) (no, I don't want to have to hook a barrel connector up to the battery if possible).
#18 Szymon
Szymon
  • 108 posts
  • LocationPoland, Krakow
Posted 26 August 2010 - 10:02 AM
If I understand you are thinking about something like with Arduino Pro?
http://www.sparkfun....roducts_id=9221
And similar with Arduino Fio (it even has LiPo charger built-in):
http://www.sparkfun....roducts_id=9712
#19 greg
greg
  • 169 posts
Posted 26 August 2010 - 01:36 PM
A faster processor would be nice. After reading CW2's writeup about how it's currently not quite fast enough to really do all the one-wire stuff (among others) even in C++ native code. Come on, you guys can beat the FEZ can't you? :)
#20 pascal06
pascal06
  • 95 posts
  • LocationFrance
Posted 26 August 2010 - 02:25 PM
For my point of view, OneWire issue is not related to processor speed. It's more related to C# latency inducted. So, the solution, like other vendors, is to provide a OneWire feature in native code and a library in C# to use it.
I use onewire with a AVR 328p at 8 Mhz !!!
My 0.2cents,
Pascal
