Experimental WIZnet Driver - klotz MyFirstWebPage Example
Posted 03 March 2011 - 03:33 PM
I'm trying to run this example from klotz, but building errors with: Error 1 Program 'C:\Users\lenovo\Documents\Visual Studio 2010\Projects\Wiznet5100v2\obj\Debug\Klotz.NETMF.Net.Wiznet5100.exe' does not contain a static 'Main' method suitable for an entry point CKlotzManDo.NETMF.Net.Wiznet5100
Any ideas where I'm going wrong? Sorry if this is more of a general noob question than netduino specific one.
Posted 04 March 2011 - 12:18 PM
In the Solution Explorer window of Visual Studio: make sure that your startup project is your test application, and not the library from Klotz. Then you should be ready to go.Netduino + WIZnet Shield - My First Webpage Example
Posted 05 March 2011 - 03:33 PM
An unhandled exception of type 'System.InvalidOperationException' occurred in FEZPanda_GHIElectronics.NETMF.FEZ.dll
Additional information: FEZ Panda not detected!
In troubleshooting, I replaced the wiznet instantiation with one of Klotz's commented out ones.
Replacing:
CKlotzManDo.NETMF.Net.Wiznet5100 wiznet = new CKlotzManDo.NETMF.Net.Wiznet5100(SPI.SPI_module.SPI1, (Cpu.Pin)FEZ_Pin.Digital.Di10);
With:
CKlotzManDo.NETMF.Net.Wiznet5100 wiznet = new CKlotzManDo.NETMF.Net.Wiznet5100(SPI.SPI_module.SPI1, Pins.GPIO_PIN_D10);
This still produces the same "FEX Panda not detected!" error, but unlike the with old line, I can continue and deployment completes. The listening port functions and serves the webpage. Success!
Moving forward, I did have to change the code further as mentioned here in order to get it to connect more than once.
So I'm up and running, though I'd be interested if anyone has thoughts on the FEZ Panda error.
Posted 05 March 2011 - 03:47 PM
In Visual Studio, remove the FEZ assemblies such as FEZPanda_GHIElectronics.NETMF.FEZ from your references, and the error will go awaySo I'm up and running, though I'd be interested if anyone has thoughts on the FEZ Panda error.
Posted 05 March 2011 - 05:08 PM
Ah, perfect - it works great. Thanks for bearing with me.
