Cannot deploy to old Netduino Plus
deploy firmware
#1 BanksySan
BanksySan
  • 28 posts
  • LocationBristol, United Kingdom
Posted 03 April 2016 - 05:57 PM
I have a pretty old Netduino Plus.
I've just got it out and dusted it off, installed the prerequisites on my new Windows 10 machine but now I can't deploy to it.
When I ping with MFDeploy I get:
Pinging... Found debugger!
NoConnection
Create TS.
 Loading start at 14d324, end 162e8c
If I select Device Configuration it just returns:
Not Supported
I suspect I have some out of date firmware.    Maybe the Micro Framework has incremented a bit since I was last playing with it.
I've tried following the instructions here: http://forums.netdui...-firmware-v431/
The update tool doesn't see my device at all, and I can't figure out what I'm supposed to to (if anything) with the STDFY_Drivers that's linked to.
Any help?
Dave
#2 BanksySan
BanksySan
  • 28 posts
Posted 03 April 2016 - 08:25 PM
I've got a bit further.  I was plugging in via a USB hub, plugging directly into the PC gets me further.  Now when I ping I get
Pinging... TinyCLR
Which I seem to remember is a good thing.
Now when I run via Visual Studio I get:
Found debugger!
Create TS.
Attaching file.
Assembly: mscorlib (4.1.2821.0) (3880 RAM - 33236 ROM - 19134 METADATA)
Attaching file.
Assembly: Microsoft.SPOT.Native (4.1.2821.0) (1144 RAM - 6516 ROM - 4479 METADATA)
Attaching file.
Assembly: Microsoft.SPOT.Hardware (4.1.2821.0) (1752 RAM - 11440 ROM - 7371 METADATA)
Attaching file.
Assembly: Microsoft.SPOT.Net (4.1.2821.0) (704 RAM - 5060 ROM - 2452 METADATA)
Attaching file.
Assembly: System (4.1.2821.0) (872 RAM - 5992 ROM - 3206 METADATA)
Attaching file.
Assembly: Microsoft.SPOT.IO (4.1.2821.0) (740 RAM - 4620 ROM - 2522 METADATA)
Attaching file.
Assembly: System.IO (4.1.2821.0) (1548 RAM - 13292 ROM - 5862 METADATA)
Attaching file.
Assembly: Microsoft.SPOT.Hardware.SerialPort (4.1.2821.0) (512 RAM - 3488 ROM - 1543 METADATA)
Attaching file.
Assembly: Microsoft.SPOT.Hardware.Usb (4.1.2821.0) (580 RAM - 3740 ROM - 1844 METADATA)
Attaching file.
Assembly: SecretLabs.NETMF.Hardware (4.1.0.0) (256 RAM - 1108 ROM - 491 METADATA)
Attaching file.
Assembly: SecretLabs.NETMF.Diagnostics (4.1.0.0) (180 RAM - 440 ROM - 166 METADATA)
Attaching deployed file.
Assembly: SecretLabs.NETMF.Hardware.Netduino (4.1.0.0) (268 RAM - 796 ROM - 423 METADATA)
Assembly: NetduinoApplication1 (1.0.0.0) (196 RAM - 388 ROM - 175 METADATA)
Assembly: GoBus (1.0.0.0) (540 RAM - 4016 ROM - 1631 METADATA)
Resolving.
Link failure: some assembly references cannot be resolved!!
Assembly: GoBus (1.0.0.0) needs assembly 'mscorlib' (4.2.0.0)
Assembly: GoBus (1.0.0.0) needs assembly 'Microsoft.SPOT.Hardware' (4.2.0.0)
Assembly: GoBus (1.0.0.0) needs assembly 'Microsoft.SPOT.Native' (4.2.0.0)
Error: a3000000
Waiting for debug commands...
The program '[4] Micro Framework application: Managed' has exited with code 0 (0x0).
So... still can't run anything but I think it's a step in the right direction.
#3 Nevyn
Nevyn
  • 1070 posts
  • LocationNorth Yorkshire, UK
Posted 04 April 2016 - 05:30 AM
It sounds like you have a different version f the firmware on the board to the one you are trying to compile against.
When looking at the new firmware make sure you get the one for the N+ and not the N+2 or N+3 boards as the microcontroller changed for these boards.
#4 BanksySan
BanksySan
  • 28 posts
Posted 04 April 2016 - 12:39 PM
Thanks Nevyn,
I guess this is the one I should be using?  http://forums.netdui...-v420-update-1/
However, I'm still getting troubles.
When I go to Device Capabilities on MFDeploy, it just says `Not Supported`.
I tried deploying anyway, I get through the config deployment but fail with an error dialogue box.
.NET Micro Framework Deployment Tool
Error: Unable to deploy to device
OK
