Netduino 3 Wifi connectivity failure mode handling
Netduino3 Wifi
#1 KiwiDev
KiwiDev
  • 100 posts
  • LocationNew Zealand
Posted 20 September 2015 - 08:47 AM
Hi all,
As part of an Azure Event Hub field gateway project I'm working on I was doing some testing and noticed I could reliably lock the device/network stack up.
I was checking how my AMQP Net Lite code reacted when network connectivity was lost, Initially I though it was my code (as it was unlikely to be an AMQP Net Lite issue) but now I think it might be something in the IP stack.
To try and isolate the problem I built a small application which does an HTTP request as this was the simplest repro I could come up with
My Netduino 3 Wifi reliably connects to the Wireless Access Point in my office, then waits for an IP address and starts making http requests.
If I pull the LAN cable out of the back of the WAP the requests fail as expected
HTTP Status:200 :  OK
A first chance exception of type 'System.Net.Sockets.SocketException' occurred in Netduino.IP.LinkLayers.CC3100
A first chance exception of type 'System.Net.WebException' occurred in System.Http.dll
Then when I plug the cable back in, the HTTP requests start working again
So far so good, but if I power down the WAP the requests fail as expected and the WLAN connectivity LED on the N3 goes yellow.
 NetworkChange_NetworkAvailabilityChanged False
If I power the WAP back up, after a while the WLAN connectivity LED on the N3 goes Green. There is a network connectivity change notification but when the next HTTP request is initiated the devices hangs
 NetworkChange_NetworkAvailabilityChanged True
The code is attached for those who want to follow along at home
Any suggestions as to why and how I can work around this?
@KiwiBryn
blog.devmobile.co.nz
         // Wait for Network address if DHCP
         NetworkInterface networkInterface = NetworkInterface.GetAllNetworkInterfaces()[0];
         if (networkInterface.IsDhcpEnabled)
            Debug.Print(" Waiting for DHCP IP address");
            while (NetworkInterface.GetAllNetworkInterfaces()[0].IPAddress == IPAddress.Any.ToString())
               Debug.Print(" .");
               Thread.Sleep(250);
         // Display network config for debugging
         Debug.Print("Network configuration");
         Debug.Print(" Network interface type : " + networkInterface.NetworkInterfaceType.ToString());
         Debug.Print(" MAC Address : " + BytesToHexString(networkInterface.PhysicalAddress));
         Debug.Print(" DHCP enabled : " + networkInterface.IsDhcpEnabled.ToString());
         Debug.Print(" Dynamic DNS enabled : " + networkInterface.IsDynamicDnsEnabled.ToString());
         Debug.Print(" IP Address : " + networkInterface.IPAddress.ToString());
         Debug.Print(" Subnet Mask : " + networkInterface.SubnetMask.ToString());
         Debug.Print(" Gateway : " + networkInterface.GatewayAddress.ToString());
         foreach (string dnsAddress in networkInterface.DnsAddresses)
            Debug.Print(" DNS Server : " + dnsAddress.ToString());
         NetworkChange.NetworkAvailabilityChanged += NetworkChange_NetworkAvailabilityChanged;
         NetworkChange.NetworkAddressChanged += NetworkChange_NetworkAddressChanged;
            try
               //WebProxy proxy = new WebProxy("10.0.0.37", 8888);
               using (HttpWebRequest request = (HttpWebRequest)WebRequest.Create("http://www.bing.com"))
                  //request.Proxy = proxy;
                  request.Method = "GET";
                  request.ContentType = "text/html; charset=utf-8";
                  request.KeepAlive = false;
                  using (var response = (HttpWebResponse)request.GetResponse())
                     Debug.Print("HTTP Status:" + response.StatusCode + " : " + response.StatusDescription);
            catch (Exception ex)
               Debug.Print(ex.Message);
            Thread.Sleep(1000);
      static void NetworkChange_NetworkAvailabilityChanged(object sender, NetworkAvailabilityEventArgs e)
         Debug.Print(" NetworkChange_NetworkAvailabilityChanged " + e.IsAvailable);
      static void NetworkChange_NetworkAddressChanged(object sender, EventArgs e)
         Debug.Print("NetworkChange_NetworkAddressChanged " + networkInterface.IPAddress);
Posted 20 September 2015 - 05:27 PM
Hi KiwiDev,
Interesting. The new network stacks should be resilient against this sort of thing. My main concern normally is that code needs to wait to get an IP address again after the network reconnects...but it sounds like this might be a different issue.
When you say "There is a network connectivity change notification but when the next HTTP request is initiated the devices hangs", are you experiencing a blocking call which never returns? Do you know what function is blocking? Or are you seeing a communication failure exception (as indicated in the debug output)?
If you're seeing an actual hang in the network stack, can you please create an issue at the Netduino.IP (for Wi-Fi) repo and we'll load the debug software build and step into the code to see what's going on?
Also--if this is an urgent bugfix request, please let us know that too so we can up-prioritize this...
Thank you KiwiDev,
#3 KiwiDev
KiwiDev
  • 100 posts
Posted 20 September 2015 - 07:50 PM
Added a couple of Debug.Print statements
   Debug.Print("request.GetResponse() Before");
   Debug.Print("request.GetResponse() After");
First I unplug the cable
Cable plugged back in and requests resumed.
Then I turn off the router
From the logging it looks like it hangs up in the var response = (HttpWebResponse)request.GetResponse()) on the second request after connectivity restored.
I'll do some more digging and create an issue this evening when I get home from work
@KiwiBryn
#4 KiwiDev
KiwiDev
  • 100 posts
Posted 21 September 2015 - 08:49 AM
Hi Chris
I grabbed the source from Github and re-compiled my application with it.
After several restarts I found that the application is hanging on the first call to
after the NetworkAvailabilityChanged notification indicates the network is back
Debugging down in the stack the lockup appears to be in
private InputNetworkStreamWrapper EstablishConnection(Uri proxyServer, Uri targetServer)
around line 1366 where it calls
hostEntry = Dns.GetHostEntry(proxyServer.Host);
The debugger complains that the code & binary don't match when I go further in
I noticed that when I put this line in
Debug.Print("IPAddress " + NetworkInterface.GetAllNetworkInterfaces()[0].IPAddress);
Just before the
The code then stopped in a similar way on the first call after the network connectivity restored notification
Regards
@KiwiBryn
#5 ukkiwisurfer
ukkiwisurfer
  • 32 posts
  • LocationLondon
Posted 24 October 2015 - 12:45 PM
Is there any progress on this issue?
Jason.
Also tagged with one or more of these keywords: Netduino3, Wifi
