Win10 + VS2015 + Netduino -> 'System.NotSupportedException'
Win10 VS2015
1 reply to this topic
#1 JamieDixon
JamieDixon
  • 25 posts
  • LocationCary, NC
Posted 06 September 2015 - 01:13 PM
I recently repaved a laptop where installed Win 10 and VS2015 Ultimate.
I then installed:
.NET Micro Framework SDK v4.3
.NET MF plug-in for VS2015 (http://forums.netdui...al-studio-2015/)
Netduino SDK v4.3.2.1
I then hooked up a Netduino 2 that worked fine with my Windows 8/VS2013 machine.  The Netdunino gets recognized .NET Microframework deployment tool and Visual Studio Sees it
I then did a "File -> New Project -> Netduino Application (Universal)" and added in basic "blinky" code.
When I try and run it on the Netduino I get this:
An unhandled exception of type 'System.NotSupportedException' occurred in SecretLabs.NETMF.Hardware.Netduino.dll
Here is the detail:
Found debugger!
Found debugger!
Found debugger!
Create TS.
 Loading start at 806b180, end 8086098
Assembly: mscorlib (4.3.1.0)
Assembly: Microsoft.SPOT.Native (4.3.1.0)
Assembly: Microsoft.SPOT.Hardware (4.3.1.0)
Assembly: Microsoft.SPOT.Net (4.3.1.0)
Assembly: System (4.3.1.0)
Assembly: Microsoft.SPOT.Hardware.SerialPort (4.3.1.0)
Assembly: Microsoft.SPOT.IO (4.3.1.0)
Assembly: System.IO (4.3.1.0)
Assembly: Microsoft.SPOT.Hardware.PWM (4.3.1.0)
Assembly: Microsoft.SPOT.Hardware.Usb (4.3.1.0)
Assembly: SecretLabs.NETMF.Diagnostics (4.3.1.0)
Assembly: SecretLabs.NETMF.Hardware.Netduino (4.3.1.0)
Assembly: Microsoft.SPOT.Hardware.OneWire (4.3.1.0)
Assembly: Microsoft.SPOT.Time (4.3.1.0)
Attaching deployed file.
Assembly: SecretLabs.NETMF.Hardware (4.3.1.0)
Assembly: ChickenSoftware,Netduino (1.0.0.0)
Assembly: GoBus (1.5.0.0)
Resolving.
Ready.
'Microsoft.SPOT.Debugger.CorDebug.14.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Native.dll', Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'Microsoft.SPOT.Debugger.CorDebug.14.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Hardware.dll', Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'Microsoft.SPOT.Debugger.CorDebug.14.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Net.dll', Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'Microsoft.SPOT.Debugger.CorDebug.14.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\System.dll', Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'Microsoft.SPOT.Debugger.CorDebug.14.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Hardware.SerialPort.dll', Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'Microsoft.SPOT.Debugger.CorDebug.14.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.IO.dll', Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'Microsoft.SPOT.Debugger.CorDebug.14.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\System.IO.dll', Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'Microsoft.SPOT.Debugger.CorDebug.14.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Hardware.PWM.dll', Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'Microsoft.SPOT.Debugger.CorDebug.14.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Hardware.Usb.dll', Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'Microsoft.SPOT.Debugger.CorDebug.14.dll' (Managed): Loaded 'C:\Program Files (x86)\Secret Labs\Netduino SDK\Assemblies\v4.3\le\SecretLabs.NETMF.Diagnostics.dll', Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'Microsoft.SPOT.Debugger.CorDebug.14.dll' (Managed): Loaded 'C:\Program Files (x86)\Secret Labs\Netduino SDK\Assemblies\v4.3\le\SecretLabs.NETMF.Hardware.Netduino.dll', Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'Microsoft.SPOT.Debugger.CorDebug.14.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Hardware.OneWire.dll', Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'Microsoft.SPOT.Debugger.CorDebug.14.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Time.dll', Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'Microsoft.SPOT.Debugger.CorDebug.14.dll' (Managed): Loaded 'C:\Program Files (x86)\Secret Labs\Netduino SDK\Assemblies\v4.3\le\SecretLabs.NETMF.Hardware.dll', Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
 Invalid address 0 and range 40 Ram Start 20000000, Ram end 20020000
'Microsoft.SPOT.Debugger.CorDebug.14.dll' (Managed): Loaded 'ChickenSoftware'
'Microsoft.SPOT.Debugger.CorDebug.14.dll' (Managed): Loaded 'C:\Program Files (x86)\Secret Labs\Netduino SDK\Assemblies\v4.3\le\GoBus.dll', Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
Can anyone help me?
#2 TechnoGuy
TechnoGuy
  • 51 posts
  • LocationCanada
Posted 09 September 2015 - 02:05 AM
Hi Jamie,
I tried the same on a computer with Windows 10 & VS2015 Community.
It has the same additions as you've listed, added in the same order:
  1. .NET Micro Framework SDK 4.3 (QFE2-RTM) [Jan 26 2015]  (4.3.1)
  2. VS2015 Project System Extension (VSIX Plug In) (alpha)  (netmfvs14)
  3. Netduino SDK 4.3.2.1
I was able to deploy the code to a Netduino Plus 2 without issues.  It ran fine.  Like you I created it using the Netduino Application (Universal) template.
I have compared my Debug Output to yours and have noticed some minor differences.  I've attached mine here as a .txt file.  I notice the following differences:
  • Loading start point (address different)
  • The order in which some of the assemblies load (your GoBus.dll loads much later on than mine does)
Anyway, I'm wondering if you have the latest Netduino firmware installed on your device?
There's a tool called MFDeploy that you can use to examine what you have.  You can find it on the start menu under Microsoft .NET Framework 4.3 and then .NET Micro Framework Deployment Tool.
There are separate instructions in the forum on how to use the tool, but basically do this:
  1. Device = USB (should then show NetduinoPlus2_Netduino)
  2. Target --> Connect
  3. Target --> Device Capabilities
You should see 3 lines that say "Netduino Plus 2" followed by the firmware rev.  I have 4.3.2.1.  What do you have?  If you're back-leveled, you can find the latest firmware on the downloads page.
Regards, Ian
- Ian
My Current Dev Boards:
  • 3 x Netduino Plus 2
  • 1 x Netduino 3 WiFi
Also tagged with one or more of these keywords: Win10, VS2015
