Watchdog - Netduino 3 - Netduino Forums
Watchdog
Watchdog
10 replies to this topic
#1 Riaan Mastenbroek
Riaan Mastenbroek
  • 19 posts
Posted 05 June 2015 - 07:00 AM
I have a strange problem when running my Netduino. For some reason it seems like a thread to read smsses from my GPRS shield just hangs the board at any interval. It might run 2 hours or 30 mins but then it seems like all the threads just stops.
I have read some posts on watchdogs and more specifically the hardware watchdog.
Are there any available in the market to buy or what would you recommend. I would not like to put this at a client and have to reset the device every now and then.
Riaan
#2 phantomtypist
phantomtypist
  • 142 posts
Posted 05 June 2015 - 02:33 PM
As it always is in electronics and software development, there are many solutions.
I personally use the Maxim DS1388 (http://www.maximinte...cks/DS1388.html).  You get an RTC, a watchdog timer, and also 512 bytes of EEPROM.  I use it religiously in all my projects.
You can find the driver (DS1388.cs) for it in one of my projects: https://bitbucket.or...tomtypist/ncmp/
#3 Riaan Mastenbroek
Riaan Mastenbroek
  • 19 posts
Posted 07 June 2015 - 06:21 AM
Thanks for that. I also found this module - Have you used it / seen it before?
http://www.freetroni...le#.VXPigM-qpHx
Riaan
#4 Riaan Mastenbroek
Riaan Mastenbroek
  • 19 posts
Posted 24 June 2015 - 08:04 AM
I looked at ordering but sitting in South Africa :( this is an expensive option for now. I looked at this thread:
http://forums.netdui...us/?hl=watchdog
Is there no way I can get the watchdog chip that is on the netduino to work? My netduino's will be running on a farm in a silo and difficult to come by - so I must somehow ensure it keeps running.
During testing it ran for 6 days straight but this morning stopped...so I had to manually hit the reset button and then it worked again.
This is my last hurdle and I am stuck. Any help please...
Riaan
#5 NameOfTheDragon
NameOfTheDragon
  • 112 posts
Posted 12 August 2015 - 11:31 AM
Did you get to the bottom of your hanging Netduino? I wondered if you might be seeing the same problem I am... http://forums.netdui...e-minute-after/
I thought it was random until I started setting the time...
#6 dino4net
dino4net
  • 40 posts
Posted 17 August 2015 - 04:53 PM
I would love this feature too.
Currently use the MAX6371 chip.
#7 JoopC
JoopC
  • 148 posts
Posted 17 August 2015 - 07:36 PM
In cases that i work with network trafic or external sensors who i have my doubts in good working i set a reset timer, it works perfect for me.
when i sent some data over the internet i set a timer, I know i must have a answer in 50 secs so:
Dim resetTimer As Timer = New Timer(AddressOf reset, Nothing, 50000, Timeout.Infinite)
// everything oké so dispose at the end of your routine......
resetTimer.Dispose()
// the reset sub routine..
Private Sub reset()
PowerState.RebootDevice(False)
End Sub
Even when the Netduino hangs in the thread it will reset.
I know it is a workaround but still....
#8 Nevyn
Nevyn
  • 1072 posts
  • LocationNorth Yorkshire, UK
Posted 18 August 2015 - 07:14 AM
Just wondering if using a Timer would work.  There is a problem in this thread where the interrupts do not trigger but the Timer continues.
Might have to test this...
#9 JoopC
JoopC
  • 148 posts
Posted 18 August 2015 - 08:48 AM
In your example i can not see that the interrupt is cleared and the resistor mode must be pullUp in my opinion.
I have written a class with the PIR who works excellent for me. You can have a look at the class.
edit : I have attached a file but it will not upload
edit2 : Thread.sleep in your PIR example is not recommended.
here is a example:
http://we.tl/BS6jp2M4pl
#10 NameOfTheDragon
NameOfTheDragon
  • 112 posts
Posted 18 August 2015 - 07:31 PM
I've found that the timers are quite robust and they do seem to continue to work even when other stuff is deadlocked. I haven't had much luck with PowerState.RebootDevice() though.
What I do is strap a wire from one of the digital outputs to the /RESET pin, and drive it low in a timer callback. Here's the class I've been using:
https://bitbucket.or...g.cs?at=develop
It's part of my open source TA.NetMF.Utilities package:
Project home page: http://tigra-astronomy.com/open-source
Source code: https://bitbucket.or...netmf.utilities
Install from NuGet: Install-Package TA.NetMF.Utilities
#11 kerk-akker
kerk-akker
  • 12 posts
  • LocationNetherlands
Posted 01 March 2016 - 05:24 PM
I developed my own HW watchdog ( separate PCB ). It simply plugs in between a Netduino and the power adaptor. It runs around a 4060 timer. In your code you need to add a function that gives a pulse around every 15 sec. In case there is no pulse the WD gives a reset pulse and in case that might not help it gives a power cycle on the netduino. I'm using it on all my sensitive netduino applications. Let me know if there is interest, then I can publish schema and PCB.
Br,
Arno
