UDP and ESP8266
WiFi ESP8266 Broadcast
#1 Nevyn
Nevyn
  • 1072 posts
  • LocationNorth Yorkshire, UK
Posted 28 May 2015 - 04:38 PM
Been playing around with UDP broadcasting as a way of developing a low overhead sensor network.  The basic idea is that the sensors are not transferring any "secure" data, just simple stuff like temperature etc.  The sensors would broadcast the data over WiFi and so the data should be reasonably secure as the sensor need to be logged on to the WiFi network in the first place.
Speed is proving to be an issue though.  I'm getting random responses from UDP broadcasts, sometime data is received in 2 seconds, sometime 15 and other any mixture of responses in between.
C# code is:
using System.Net;
using System.Net.Sockets;
namespace NETMFUDPServer
            //  Wait until we have an IP address.
            while (IPAddress.GetDefaultLocalAddress() == IPAddress.Any)
                Thread.Sleep(10);
            Debug.Print("IP Address: " + IPAddress.GetDefaultLocalAddress());
            EndPoint endPoint = new IPEndPoint(IPAddress.Any, 11000);
            Socket socket = new Socket(AddressFamily.InterNetwork, SocketType.Dgram, ProtocolType.Udp);
            socket.Bind(endPoint);
                if (socket.Poll(1000, SelectMode.SelectRead))
                    byte[] buffer = new byte[socket.Available];
                    int bytesRead = socket.ReceiveFrom(buffer, ref endPoint);
                    int length = buffer.Length;
                    char[] text = new char[length];
                    for (int i = 0; i < length; i++)
                        text[i] = (char) buffer[i];
                    Debug.Print("Message received from " + endPoint.ToString() + ": " + new string(text));
I know the ESP code is triggering every second as I have a console App on the PC which confirms that data is being transmitted every second.
Anyone with more experience with UDP who could help with optimisation or advise?  I know NETMF is a little slower than full .NET but the period between packets being picked up can be the best part of 15 seconds.
#2 HSven1611
HSven1611
  • 14 posts
Posted 29 May 2015 - 07:14 AM
Hi
I'm doing something like that:
  public UdpClient(int port)
            LocalPort = port;
            try
                Socket = new Socket(AddressFamily.InterNetwork, SocketType.Dgram, ProtocolType.Udp);
                Socket.SetSocketOption(SocketOptionLevel.Socket, SocketOptionName.ReuseAddress, true);
                IPEndPoint broadcastEndPoint = new IPEndPoint(System.Net.IPAddress.Any, LocalPort);
                Socket.Bind(broadcastEndPoint);
            catch
                throw;
            new Thread(new ThreadStart(threadStartTarget)).Start();
        private void threadStartTarget()
            try
                EndPoint remoteEndPoint = new IPEndPoint(System.Net.IPAddress.Any, 0);
                    int availableBytes = Socket.Available;
                    if (availableBytes > 0)
                        byte[] receiveBuffer = new byte[availableBytes];
                        Socket.ReceiveFrom(receiveBuffer, ref remoteEndPoint);
                        // My own data received Event
                        OnDataReceived(remoteEndPoint, receiveBuffer);
                    // This is recommends in thread loops to help prevent lock-ups
                    Thread.Sleep(10);
            catch (Exception e)
                // catch all exceptions
                Debug.Print(e.ToString());
            finally
                Debug.Print("UDP server thread finished.");
I remember having issues with that Poll() method too... Don't know how that thing should work.
#3 Nevyn
Nevyn
  • 1072 posts
Posted 29 May 2015 - 08:50 AM
I have tried eliminating the code which converts the packet to a string and I'm sill getting long pauses between packets.
The Poll method does return quickly, it seems to be the ReceiveFrom method which is consuming the time.
#4 bghavami
bghavami
Posted 07 January 2016 - 04:33 PM
I hope you have solved the problem by now, but if you haven't yet here is the solution.
      private static int nPort = 12345;
      private static EndPoint EndPointRemote;
      private static int nBufSize = 1024;
      public void Start()
               Thread.Sleep(10);
         EndPointRemote = new IPEndPoint(IPAddress.Any, nPort);
         socket.Bind(EndPointRemote);
         int bytesRead;
         byte[] buffer = new byte[nBufSize + 1];
            if( (bytesRead = socket.ReceiveFrom(buffer, nBufSize, SocketFlags.None, ref EndPointRemote)) > 0 )
               Debug.Print("Message received from " + EndPointRemote.ToString() + ": " + new string(System.Text.Encoding.UTF8.GetChars(buffer, 0, bytesRead)));
            Thread.Sleep(0);
Let me know if this work for you.
Bizhan.
Also tagged with one or more of these keywords: WiFi, ESP8266, Broadcast
