Finding bytes in byte array
micro framework .netmf method
#1 JBkey
JBkey
  • 14 posts
  • LocationAveiro, Portugal
Posted 12 February 2015 - 03:32 PM
Hi!
I need some advice, and I think this is the right place, if it isn't, let me know.
I'm very limited on my programming knowledge, so maybe this is an easy question to answer.
I have an array of bytes that contains values like this:
byte [] values {00, 22, 33, 44,  0x55, 55, 66, 77, 88, 99, 10}
And I need to select a number x of bytes that appear after the 0x55 into another array (I only used hex to differenciate).
byte [x] selec_values { 0x55, 55, 66, 77, 88}
I thought I could search for that byte using "array.find" and I can't. Then I tried to build a list with the array values, and... again, I can't..
Does anyone know how I do that?
JB
Edited by Chris Walker, 12 February 2015 - 07:35 PM.
Removed duplicates, clarified post subject line
#2 Mario Vernari
Posted 13 February 2015 - 11:31 AM
Aveiro, Portugal! My wife was there once, and told me it's an awesome city!
As far I know, there's no any immediate way to achieve kinda "Array.find", but of course you can create it. If you were using the regular (i.e. desktop) .Net Framework, you could use Linq, which allows to "compose" whatever function you want with ease.
For the Netduino, you can use something like that:
                var source = new byte[] { 00, 22, 33, 44, 0x55, 55, 66, 77, 88, 99, 10 };
                var index = Array.IndexOf(source, 0x55);
                var targetLength = source.Length - index - 1;
                var target = new byte[targetLength];
                source.CopyTo(target, index + 1);
Hope it helps.
#3 JBkey
JBkey
  • 14 posts
Posted 15 February 2015 - 09:15 AM
It's like a little venezia,  ;)
Before I saw your comment I reached the same solution. And it's working so far.
                int index = Array.IndexOf(readBuffer, "0x55");
                byte[] results = new byte[16];
                Array.Copy(readBuffer, index, results, 0, 16);
But I forgot something...
In the source byte[] (readBuffer), I have more than one "0x55 block" and I need all of them (I didn't know this before, I thought it would be just one block per array).. and array.copy only returns the first one. Any ideas?
Jnatas Brs
#4 Mario Vernari
Posted 17 February 2015 - 05:16 AM
Hmm...but what do you mean as "the first one"? That is, what's the expect "end of block"?
Looks like you have to deal with a kind of pattern, and you have to extract all its occurrences...
Anyway, before knowing what's you answer, you may also consider another way to deal with such a situations. It may sound as an overkill, but when you have to deal with data extraction (in general), composition, and others function to/from a byte array, the below one is maybe very neat.
http://cetdevelop.co...eArrayReader.cs
(and related classes)
It's basically a bunch of classes for byte-array manipulation: reader, writer, data extraction and insertion, etc.
Please, note that the library is a bit "aged" (about two years), but should be working fine with the latest firmwares.
#5 JBkey
JBkey
  • 14 posts
Posted 17 February 2015 - 09:19 AM
Hi.
thank you for your answer.
You are right. I need to extract all the occurrences. About the end of block I know it's the 16th byte after the "0x55" occurrence.
I'm going to study your suggestion and I'll let you know what's my decision ;)
PS. : How was the carnival? I hear that Venezian carnival is awesome.
Also tagged with one or more of these keywords: micro framework, .netmf, method
