i basically want to develop an obstacle detector. Which netduino board will suit ma goal. i will also be using an ultrasonic laser sensor to inspect the environment for obstacles, will also use and LCD display message and also be needing a sound output too. Pls help!!
obstacle detection
Posted 22 February 2014 - 05:09 PM
Posted 23 February 2014 - 07:17 AM
Hi - Welcome to the Forums,
I am using some analogue sensors from Sharp which use Infra-red light to give distances between 10cm and 80cm.
I am also using some digital Sharp sensors that just detect the presence of an object close by.
Both of these type of sensor are connected directly to the Netduino with a single input pin (analogue or digital as appropriate),
they work well for me on the Netduino plus (v1).
Since all they need is the normal IO pins I think any classic (not Go) Netduino should work straight out of the box.
This page has a link to the sensors - http://forums.netdui...4-dfrobot-buggy
Hope this helps - Paul
Posted 23 February 2014 - 10:36 PM
Paul,
I think the GO with a Shieldbase could easily achieve the same, maybe not as cheap but definitely doable.
Cheers Olaf
Van SchOten Ict Diensten en Services
http://www.voids.nl
Posted 24 February 2014 - 05:52 PM
Paul,
Cheers Olaf
Yes I agree - Go plus shield base would work fine.
Choice probably depends on final form of the project and price.
Paul
- oksekyi likes this
Posted 15 June 2014 - 11:15 PM
i have purchased the netduino 2 and also an lcd from sparkfun and hc-sr04 sensor. but the problem is both the lcd and the sensor requires 5v i can't make them work at the same time. how do i get them to work simultaneously. that is the dislpay should show distance.
Posted 16 June 2014 - 12:11 AM
If you're saying that you haven't been able to hook up both the LCD and the sensor because there is only one socket on the shield connector for 5V, then I've had the same problem. My solution was to create a couple "Y" cables. They allow me to connect multiple devices to the 5V, 3.3V and/or GND pins.
If that;s not what you're saying ... then say more ...
John
Posted 16 June 2014 - 03:02 AM
John
yes john exactly. So are u saying if i create a "Y" cable my problem will be solved. So how do i go about this? is it difficult to make one?
Chevi99
Posted 17 June 2014 - 02:32 AM
I like to use "breadboard jumper wires". They come in M/F, F/F, and even M/M configurations. You can get them from a bunch of vendors on Amazon for a few dollars. One way to do a "Y" cable would be to cut a couple M/F cables in half, strip the ends, twist them together, solder it together, and shrink wrap it. Use one male end (to plug into the Netduino) and 2 or more female ends to receive the wires from your devices.
Another way that I've done it is to solder a jumper wire with a male end to a piece of female header with 3 or 4 sockets. Solder all the pins together and put some shrink wrap on it if you want.
Do you have a soldering iron? I took a quick look on Amazon and I don't see any premade jumpers.
John
- Paul Newton likes this
Posted 17 June 2014 - 05:28 AM
John,
This is a great idea! I've thought about how to do this myself, but your idea of using headers sounds like the cheapest and simplest approach I've heard. Nice work!
However, can I ask what you mean by "shrink wrap"? Are you referring to electrical tape, or something else?
Nathan
Posted 19 June 2014 - 09:22 AM
John
Great idea John i've been abel to create my own Y cable i just took 3 male jumper wires twisted the ends together and amazingly it worked
tnx for the idea
chef
Posted 19 June 2014 - 07:58 PM
can i make my speaker give a warning message like "WARNING OBSTACLE AHEAD" i know about making musical beats but is there a way a computer voice will speak rather than beep?
Posted 19 June 2014 - 08:36 PM
There some mp3 modules on the market you could use for that.
http://www.voids.nl
Posted 03 July 2014 - 11:36 AM
Paul,
Cheers Olaf
Also tagged with one or more of these keywords: netdunio, ultrasonic laser sensor, LCD, Obstacles, potholes
Hardware →
Netduino 3 →
Netduino frameworkStarted by ukkiwisurfer, 19 Jan 2016 ![]() |
General →
Project Showcase →
Adafruit RGB LCD ShieldStarted by giawa, 19 Jul 2015 ![]() |
General →
General Discussion →
Anyone used a ST7565 GLCD????Started by david98xp, 28 Nov 2014 ![]() |
Hardware →
Netduino 2 (and Netduino 1) →
N2 + I2C 1602 LCDStarted by FredOrJoeBlogs, 11 Aug 2014 ![]() |
General →
Driver for LCD with I2C backpackStarted by Esben, 08 Aug 2014 ![]() |
