uNFC - NFC library - Netduino Plus 2 (and Netduino Plus 1) - Netduino Forums
uNFC - NFC library
nfc pn532 nxp
9 replies to this topic
#1 Paolo Patierno
Paolo Patierno
  • 169 posts
  • LocationItaly
Posted 22 January 2014 - 09:04 AM
Hello,
I developed an NFC library that supports .Net Micro Framework 4.2 and 4.3 (and other frameworks).
For now, it supports NXP PN532 chip with all possible communication channels (I2C, SPI and HSU).
You can find it at following links on CodePlex and Code Gallery :
https://unfc.codeplex.com/
http://code.msdn.mic...ibrary-d0744dab
I hope it could be useful !!
Paolo.
Paolo Patierno
Azure Advisor
Twitter : @ppatierno
Linkedin : paolopatierno
Blog : DevExperience
Blog : Embedded101
#2 gomore11
gomore11
  • 87 posts
Posted 22 January 2014 - 11:46 AM
Hi Paolo!!
Great job!!! I´ve been working on this also some time ago. But I came across with a problema when I tried to communicate a Netduino2+ Adafruit NFC shield(PN532 chip) and a Windows phone..........Have you done any kind of test in something similar to this????
#3 Paolo Patierno
Paolo Patierno
  • 169 posts
  • LocationItaly
Posted 22 January 2014 - 11:51 AM
I testd the library with Netduino Plus (first generation) but I will test it also with Netduino Plus 2 (you can start to test if you want :-))
I used following breakout board :
http://www.elecfreak...22eq85jj9pa1me1
Paolo.
Paolo Patierno
Azure Advisor
Blog : Embedded101
#4 vz10
vz10
  • 8 posts
Posted 11 August 2014 - 06:15 AM
Hi, I want to try to conned NFC to my Netduino Plus 1. Will it work with this NFC? And how to connect them together?
#5 vz10
vz10
  • 8 posts
Posted 30 November 2014 - 09:29 AM
I can't run this library on netduino plus, because netduino uses microframework 4.1 and library needs 4.2. Is there any way to solve this problem?
#6 Nicolas Besson
Nicolas Besson
  • 9 posts
Posted 02 December 2014 - 09:53 AM
Hi vz10, I'm pretty sure that the library can work on 4.1 too. For this, create a new 4.1 project and import the cs files shared by Paolo.
Hope that you will succeed.
#7 vz10
vz10
  • 8 posts
Posted 02 December 2014 - 10:00 AM
I've already tried it, but I've got a lot of errors like "unknown name in this namespace", which didn't appear when I triedit in 4.2 version.
#8 Paolo Patierno
Paolo Patierno
  • 169 posts
  • LocationItaly
Posted 02 December 2014 - 10:03 AM
Hi all,
excuse but I'm very busy with my other open source projects...for example M2Mqtt :-)
However ...
Hi vz10 can you share more details about "unknown name in this namespace" errors you have ?
Paolo.
Paolo Patierno
Azure Advisor
Blog : Embedded101
#9 366cobra
366cobra
  • 16 posts
Posted 07 December 2014 - 10:37 AM
Hi Paolo,
Thanks for doing the hard yards.
I have got the following NFC board http://www.aliexpres...2038722238.html
Have configured it to use I2C, but not having any luck communicating with it.
Using 2.2KOhm pull up resistors and have tried both 3.3V and 5V.
The Execute in I2CWrite fails with write = 0
Any idea on what it could be?
PN532 is a specific chip from one company only, right?
I have an I2c lux meter and that works fine.
NP2
FW 4.3.1
Can't wait for my Agent watch to arrive..........
#10 vz10
vz10
  • 8 posts
Posted 05 February 2015 - 11:28 AM
I've made it finally. And it works very good, thanks for the great work you've done.
But sometimes I got exception "System.ArgumentOutOfRangeException', on some kinds of nfc labels.
Also tagged with one or more of these keywords: nfc, pn532, nxp
