Adafruit data logger SD card communication
sd card spi adafruit shield exception
8 replies to this topic
#1 HaxyMaxy
HaxyMaxy
  • 7 posts
Posted 22 January 2014 - 02:18 AM
I am unable to communicate with an SD card attached to a netduino 1 (formatted 4.2.0.1) via adafruit pre assembled SD card
logger shield.
using System;using System.IO;using Microsoft.SPOT.IO;using System.Threading;using Microsoft.SPOT;using Microsoft.SPOT.Hardware;using SecretLabs.NETMF.Hardware;using SecretLabs.NETMF.IO;using SecretLabs.NETMF.Hardware.Netduino;namespace _2010testapp{    public class Program    {	    public static void Main()	    {		    StorageDevice.MountSD("SD1", SPI_Devices.SPI1, Pins.GPIO_PIN_D10);		    string[] directories = System.IO.Directory.GetDirectories(@"");		    Debug.Print("directory count: " + directories.Length.ToString());		    for (int i = 0; i < directories.Length; i++)		    {			    Debug.Print("directory: " + directories[i]);		    }		   			 string[] files = System.IO.Directory.GetFiles("SD1");		    Debug.Print("file count: " + files.Length.ToString());		    for (int i = 0; i < files.Length; i++)		    {			    Debug.Print("file: " + files[i]);		    }		    while (true)		    {		    }	    }    }}
when it gets to the line "string[] files = System.IO.Directory.GetFiles("SD1");"
I get an exception "An unhandled exception of type 'System.IO.IOException' occurred in System.IO.dll"
I have tried with a 4 gb micro sd card in an adapter and a 16gb sd card.
both have been tried in every format availible in the built in windows sd card formatter.
Thank you in advance for any insight to my problem,
Maxwell
#2 ShVerni
ShVerni
  • 138 posts
  • LocationNew York, New York
Posted 22 January 2014 - 06:18 PM
Hello Maxwell,
I think your first problem might be that the Netduino only officially supports SD cards up to 2GB. Have a look at this post: http://forums.netdui...ard/#entry47779
 Also, you may want to try changing this line
string[] files = System.IO.Directory.GetFiles(@"SD1");
to this:
string[] files = System.IO.Directory.GetFiles(@"SD1\");
I hope that helps!
#3 HaxyMaxy
HaxyMaxy
  • 7 posts
Posted 24 January 2014 - 01:15 AM
I tried changing the line and it still threw the exception. I will try to see if i can get my hands on a non sdhc sd card.
#4 wendo
wendo
  • 85 posts
Posted 24 January 2014 - 01:28 AM
You typically need to double the backslashes so they don't act as escape chars.
This is working code from an N+2
 FileStream filestream = new FileStream(@"SDsettingsWhitelist.txt", FileMode.Open);
#5 ShVerni
ShVerni
  • 138 posts
Posted 24 January 2014 - 02:25 AM
This is true, however, the use of the "@" symbol before a string indicates it's a verbatim string literal, which precludes the need to escape things:
http://msdn.microsof...0(v=vs.71).aspx
#6 HaxyMaxy
HaxyMaxy
  • 7 posts
Posted 24 January 2014 - 06:29 AM
2gb card in the mail, will report back with results.
#7 ShVerni
ShVerni
  • 138 posts
Posted 25 January 2014 - 07:17 PM
Good luck!
#8 HaxyMaxy
HaxyMaxy
  • 7 posts
Posted 27 February 2014 - 11:17 AM
The code works fine with a 1gb sd card. Thanks for the help. Hopefully support is added for sdhc in the near future.
#9 ShVerni
ShVerni
  • 138 posts
Posted 28 February 2014 - 08:42 PM
Excellent!
Also tagged with one or more of these keywords: sd, card, spi, adafruit, shield, exception
