Disregard my previous post. I installed as I wrote and it works. Sorry.
Beta: Visual Studio 2013 support
#61
Posted 07 November 2014 - 07:41 PM
#62
Posted 12 November 2014 - 07:12 PM
I'm new to Netduino and just received my new Netduino Plus 2, but I am seeing an error with VS2013 when I try to create a new project using the Netduino Plus 2 application template:
There is a missing project subtype
Subtype: '{b69e3092-b931-443c-abe7-7e7b65f2a37f}' is unsupported by this installation
I have the following installed:
VS2013 Update 3
Microsoft .Net MF SDK 4.3 (SDK-R2-Beta)
Netduino SDK v4.3.1 (February 2014)
As an FYI: I originally tried it with VS2010 and it works fine, but I'd really like to get this working in 2013 to use all the latest stuff related to Azure ISS.
Posted 21 November 2014 - 10:35 PM
will this work with the just-released visual studio 2013 "community edition" which is supposed to be a free version of pro??!?
#64
Posted 25 November 2014 - 01:32 AM
h3mp - i tried to get it working with visual sutdio 2013 community - but i had no luck. I could not get anything, even an empty console app to build properly. I would love to know if you or anyone else has some success.
#65
Posted 30 November 2014 - 11:39 PM
"Experimental" tag has been removed.
Posted 30 November 2014 - 11:41 PM
The NETMF 4.3 R2 SDK may support VS2013 Community Edition, but we haven't tested that scenario quite yet. If it doesn't work for you (running the NETMF 4.3 R2 Beta SDK installer and then the VS2013 VSIX), let me know and I'll ping the .NET MF team at Microsoft again on this.will this work with the just-released visual studio 2013 "community edition" which is supposed to be a free version of pro??!?
Posted 30 November 2014 - 11:42 PM
Are things working now for you, with this latest update?
Posted 03 December 2014 - 01:07 AM
Hello everyone,
I've a problem with the latest firmware. I upgrated mi Netduino plus 2 with the new 4.3.1 MF. I completed the upgrade successfully, but when i try to run my application, the VS2013 reboot the netduino because it's not in debug mode. From this moment my Netduino turns in DFU mode and remains in this way even if i reset it ( by button and by power off).
I tried all the methods i finded in this forum, i installed all the updats i finded ... but it doesn't work.
But ... magically .... if i reinstall the 4.2.1 MF, my Netduino begin to work normally.
Can you help me ?
Thank you
#70
Posted 09 December 2014 - 01:53 PM
this link appears broken http://www.netduino....MF43R2_Beta.msi
Ya
This link is broken. the binary has been moved. Can someone post where it went to?
-Peter
#71
Posted 09 December 2014 - 05:30 PM
Hello everyone,
Can you help me ?
Thank you
I used the Update App and fixed mine. I was running 4.2 and went to 4.3 after that VS started working ok
#72
Posted 10 December 2014 - 12:05 PM
#73
Posted 13 December 2014 - 12:36 PM
Ya
-Peter
can you fix this download link please Chris
Just download it from here: https://netmf.codeplex.com/
#74
Posted 16 December 2014 - 10:07 AM
Hi ccondo,
I had same problem.
1. Install MF SDK
2. Install ND SDK
3. Install netmfvs2013.vsix
4. All works fine
#75
Posted 27 December 2014 - 05:46 AM
Fixed Thanks for letting me know, h3mp!this link appears broken http://www.netduino....MF43R2_Beta.msi
Posted 31 December 2014 - 05:35 PM
VS 2013 support with Firmware 4.3.1 is a welcome upgrade form VS2010 for me!!
Kudos Chris & Team
#77
Posted 10 January 2015 - 10:19 AM
Hi guys,
Does netduino SDK rely on .net mf 4.2?
I've installed .net mf 4.3 beta and only 4.3 target. Then installed netdiono sdk 4.3.1 and I am getting this error when creating a new netduino project (in VS2013):
"The imported project "C:\Program Files (x86)\MSBuild\Microsoft\.NET Micro Framework\v4.2\CSharp.Targets" was not found. Confirm that the path in the <Import> declaration is correct, and that the file exists on disk"
UPDATE: If I install 4.2 target as well it works. So, is this by design?
Miha Markic, Microsoft MVP C#
Righthand .net consulting and software development
http://blog.rthand.com/
#78
Posted 10 January 2015 - 10:37 AM
Nevermind, I see now that netduino "the original" is stuck at 4.2. It makes sense now.
#79
Posted 11 February 2015 - 06:22 PM
Hi
My board is 4.3.0
I made a reinstall of sdk and it now is 4.3.1.
How can I compile using sdk 4.3.1 to my board using 4.3.0 ???
I can't deploy because 'mscorlib' on board is diffferent, and at project creation there is only 4.2 or 4.3 to select
#80
Posted 17 February 2015 - 12:14 AM
I installed Visual Studio 2013 yesterday everything is working great!
