Installing Toolsets
GPS
#1 miltonkbenjamin
miltonkbenjamin
  • 22 posts
Posted 24 December 2013 - 01:23 AM
All,
After unpacking one tool box, i get in c:programfiles (x86)netfmToobox.com    :
/.NET Micro Framework Toolbox/Assemblies/v4.1/be/Toolbox.NETMF.Hardware.NmeaGps.dll ./.NET Micro Framework Toolbox/Assemblies/v4.1/be/Toolbox.NETMF.Hardware.NmeaGps.pdb ./.NET Micro Framework Toolbox/Assemblies/v4.1/be/Toolbox.NETMF.Hardware.NmeaGps.pdbx ./.NET Micro Framework Toolbox/Assemblies/v4.1/be/Toolbox.NETMF.Hardware.NmeaGps.pe ./.NET Micro Framework Toolbox/Assemblies/v4.1/le/Toolbox.NETMF.Hardware.NmeaGps.dll ./.NET Micro Framework Toolbox/Assemblies/v4.1/le/Toolbox.NETMF.Hardware.NmeaGps.pdb ./.NET Micro Framework Toolbox/Assemblies/v4.1/le/Toolbox.NETMF.Hardware.NmeaGps.pdbx ./.NET Micro Framework Toolbox/Assemblies/v4.1/le/Toolbox.NETMF.Hardware.NmeaGps.pe ./.NET Micro Framework Toolbox/Assemblies/v4.1/Toolbox.NETMF.Hardware.NmeaGps.dll ./.NET Micro Framework Toolbox/Assemblies/v4.1/Toolbox.NETMF.Hardware.NmeaGps.pdb ./.NET Micro Framework Toolbox/Assemblies/v4.2/be/Toolbox.NETMF.Hardware.NmeaGps.dll ./.NET Micro Framework Toolbox/Assemblies/v4.2/be/Toolbox.NETMF.Hardware.NmeaGps.pdb ./.NET Micro Framework Toolbox/Assemblies/v4.2/be/Toolbox.NETMF.Hardware.NmeaGps.pdbx ./.NET Micro Framework Toolbox/Assemblies/v4.2/be/Toolbox.NETMF.Hardware.NmeaGps.pe ./.NET Micro Framework Toolbox/Assemblies/v4.2/le/Toolbox.NETMF.Hardware.NmeaGps.dll ./.NET Micro Framework Toolbox/Assemblies/v4.2/le/Toolbox.NETMF.Hardware.NmeaGps.pdb ./.NET Micro Framework Toolbox/Assemblies/v4.2/le/Toolbox.NETMF.Hardware.NmeaGps.pdbx ./.NET Micro Framework Toolbox/Assemblies/v4.2/le/Toolbox.NETMF.Hardware.NmeaGps.pe ./.NET Micro Framework Toolbox/Assemblies/v4.2/Toolbox.NETMF.Hardware.NmeaGps.dll ./.NET Micro Framework Toolbox/Assemblies/v4.2/Toolbox.NETMF.Hardware.NmeaGps.pdb
How would I import these tools into the Microsoft Visual C# toolbox menu?  What is the
difference between  le and  lb?  What does pe, pdbx and pdb mean?
Milt
Posted 24 December 2013 - 02:20 AM
Hi Milt,   If your application is using .NET Micro Framework 4.1 (and Netduino 4.1 firmware), add this file as a reference to your project:
If your application is using .NET Micro Framework 4.2 (and Netduino 4.2 firmware), add this file as a reference to your project:
The "le" and "be" folders contain microcontroller-specific binaries (for little-endian and big-endian micros, respectively). When you add the root DLL, Visual Studio knows where to look for the micro-specific binaries. Chris P.S. When you add the DLL as a reference, it will appear in Project References and you'll be able to use them from code. These aren't .NET GUI-style components, so they won't show up in the control toolbox. Chris
#3 Nevyn
Nevyn
  • 1072 posts
  • LocationNorth Yorkshire, UK
Posted 24 December 2013 - 09:30 AM
Personally I don't add the precompiled DLLs if I have the source code available to me.  I prefer to add sources for classes I need to my projects.  That way you do not have to worry about the versions.  Also, it means in a memory constrained environment such as Netduino you are only using the memory you really need.
#4 miltonkbenjamin
miltonkbenjamin
  • 22 posts
Posted 24 December 2013 - 11:42 PM
Ok,
I got the NmeaGps  name space defined bu including:
using Toolbox.NETMF.Hardware;
Now "Tools" is not defined in
  "Debug.Print("http://www.bing.com/maps/?q=" + Tools.RawUrlEncode(Gps.Latitude.ToString() + " " + Gps.Longitude.ToString()));"
Where do I find "Tools" ?
Milt
#5 Chris Walker
Posted 25 December 2013 - 04:46 AM
Hi Milt, Are there other applications (or samples) out there using the library you're consuming? If so, you can open them up and then right-click on the "Toolbox" keyword to figure out what namespace it's in, what it's defined, etc. Chris
Also tagged with one or more of these keywords: GPS
