Flashing Go Modules using ST Microelectronics’ Flash Loader Demonstrator
Posted 10 October 2012 - 10:32 PM
http://www.youtube.com/watch?v=jB3nFQso2Vs
Cheers,
-Fabien.
Links & References
Nwazet Source repository
Nwazet firmware files
Map file for the STM32F051x
Adafruit FTDI Friend + extras - v1.0
Adafruit USB FTDI cable - TTL-232R 3.3V
Sparkfun FTDI Basic Breakout - 3.3V
Sparkfun FTDI Cable 5V VCC-3.3V I/O
ST Flash Loader Demonstrator
Netduino Go! IDC Cable Breakout
Netduino GO! Hacking - Breaking out sockets
- CW2, Arron Chapman and Dan T like this
Posted 11 October 2012 - 12:02 AM
For those of you looking for a single row breadboard breakout for the Go socket, I sell them for $5 assembled (and $3.50 for just the PCB) here, if you can stand the Gadgeteer logo The pinout is the same. They are also OSHW with Eagle design files available on the linked page, if you want to have some fabbed (oshpark is high quality and very reasonable).
Posted 11 October 2012 - 01:31 AM
Posted 11 October 2012 - 01:37 AM
ransomhall -- direct flashing options like this can be very useful...especially when testing custom firmware.Fabien - thanks for the video. I used the STM32ReflashApp to update the ShieldBase recently without issue, but am glad to know about the Go firmware corruption problem. I like your "direct" method better.
Two quick notes on the STM32 beta flashing app (mentioned in the video):
1. We made updates to the STM32 beta flashing app a while ago which include a workaround for the NETMF resources bug. Users are reporting a 100% success rate with arbitrary binaries; the module manufacturer just needs to run the binary through the LengthenBinFile program first.
2. The data corruption (or more accurately deployment misalignment) issue is particular to the 4.2.0.2 firmware. It seems to happen when deploying firmware updates >128KB. We've posted a patch for the original 4.2.0.0 firmware...and we'll be incorporating that patch into the upcoming 4.2.0.3 firmware later this month.
We're addressing both issues with Microsoft for NETMF 4.3 as well...so the one-time workarounds won't be necessary.
Posted 11 October 2012 - 03:00 AM
I have used this method several times now and have loved it. I originally saw it posted in a previous Touch Display thread a while back, but had only recently tried it out with your help. I have also started to use the Komodex go!bus Breakout Module instead of my IDC breakout from Proto-advantage. Both work great, but with the Komodex go!bus Breakout Module I have the additional option of flashing with an ST-Link as well. So in case there are some people that don't have the Proto-Advantage IDC breakout, but they do have the breakout module, here's another option.
komodex-BreakoutModule-flashing.jpg 98.15KB 26 downloads
As you can see I have both options on one breadboard for demonstration purposes, but prefer the Komodex option. I believe they should be getting more in stock pretty soon.
One word of caution with my setup is the USB-UART dongle I am using is really cheap ($2.00), and I find that it does not source enough amps and is running at about 3.25V. Sometimes it worked, sometimes it didn't, but now I am using an external 3.3V power source and it works brilliantly. I guess you get what you pay for.
Anyway, thank you Fabien for showing us another option to flash modules.
Cheers,
Steve
- Fabien Royer likes this
Twiiter: https://twitter.com/Gutworks
Posted 11 October 2012 - 06:26 AM
Posted 11 October 2012 - 02:56 PM
Hi CW2,Thanks for the video, Fabien. If I understand it correctly, this mechanism can be used to flash only STM8 microcontrollers which have the bootloader, right?
I don't know all of the technical details behind the software, however I do know that it works on the STM32 family as both the touch display and DAQ can be updated using this process as long as you use the correct map file.
Steve
Edit: I now understand the question after Fabien's response and realize how redundant my response was. Sorry!
Edited by Gutworks, 11 October 2012 - 05:25 PM.
Posted 11 October 2012 - 05:07 PM
Posted 11 October 2012 - 06:29 PM
Posted 13 October 2012 - 05:09 AM
I had a look at these a while back and thought it was a great idea, and you can't beat the price!
