Netduino Firmware v4.2.0 BETA 1
83 replies to this topic
#61 ColinR
ColinR
  • 142 posts
  • LocationCape Town, South Africa
Posted 05 July 2011 - 05:09 AM
The MSDN example suggests..
// Create an instance of StreamReader to read from a file.
// The using statement also closes the StreamReader.
using (StreamReader sr = new StreamReader("TestFile.txt"))
    String line;
    // Read and display lines from the file until the end of
    // the file is reached.
    while ((line = sr.ReadLine()) != null)
        Console.WriteLine(line);
Link
#62 Chris Walker
Posted 05 July 2011 - 05:23 AM
Hmm. Thanks for the details. Very interesting. Two questions: 1. Does ColinR's sample work as a workaround? 2. Does your example work with files on Windows (i.e. is the behavior inconsistent between .NET and .NET MF)? Chris
#63 grimbouk
grimbouk
  • 8 posts
Posted 05 July 2011 - 07:44 AM
Two questions:
Very interesting. I wonder if that has become the recommended way to check for EndOfStream? If you search you'll find that a lot of people give examples they way I use EndOfStream. I managed to find one official example as well: http://msdn.microsof...y/ee461504.aspx (step 9).
Answers:-
2. This design pattern does work in the standard framework as I use it quite often.
1. Interesting, this pattern manages to read all the lines, but doesn't stop trying to read lines when the EndOfStream is hit:-
Debug.Print(File.Exists(filename) ? "File Found" : "File Not Found!");
using (StreamReader sr = new StreamReader(filename))
        Debug.Print("Initial EOS:" + sr.EndOfStream.ToString());
        String line;
            Debug.Print("LINE:" + line + " - EOS:" + sr.EndOfStream.ToString());
This gived me the following output...
File Found
Initial EOS:True
LINE:TestLine0 - EOS:False
LINE:TestLine1 - EOS:False
LINE:TestLine2 - EOS:False
LINE:TestLine3 - EOS:False
LINE:TestLine4 - EOS:True
LINE: - EOS:True
LINE: - EOS:True
LINE: - EOS:True
So it looks like EndOfStream isn't set until the first line is read.
If I step over the code, "line" is never set to null, if there's no data available it seems to be set to empty string. I wouldn't be happy to use this to determin the end of file.
It looks like I can get what I want by using a mix of this approach and adding a check for EndOfStream within the loop, like this:-
    String line;
        if (sr.EndOfStream) break;
Tim
#64 ColinR
ColinR
  • 142 posts
Posted 05 July 2011 - 08:59 AM
Sounds like a bug then - but with a neat workaround.
Return Value
Type: System.String
The next line from the input stream, or null if the end of the input stream is reached.
Link
#65 Edward
Edward
  • 38 posts
  • LocationLondon, UK
Posted 05 July 2011 - 10:13 AM
We build the tuning down of buffer sizes into the v4.1.0.0 firmware, and it's now included in the v4.2 firmware as well.
What is the FAT file access count memory issue? If that has been changed in the 4.2 codebase, it's included as well.
The GC bugfixes are included for sure.
We'll be posting v4.2 beta 2 later this weekend, now with "WithEvents" support for VB programmers.
Not FAT file access count - in a previous thread (that I can't now find) relating to out of memory issues you'd said you were going to reduce both the number and size of buffers allocated by the FAT file system. You also said in that thread you were going to change the wording of the GC message "Failed to allocate..." to clarify that it was a compaction trigger rather than an out of memory situation. The old wording remains so I wondered if the memory tuning got done and whether all this is in 4.2.
Thanks for clearsing this up.
Edward
#66 Stuart Crawshaw
Stuart Crawshaw
  • 60 posts
  • LocationLeeds, United Kingdom
Posted 05 July 2011 - 10:37 AM
Hi all, Does this beta include the OneWire support by CW2? On another note, Since updating i can no longer deploy to my Netduino... I just sticks at deploying... I did notice however that when updating with MFDeploy, the output did not seem "complete" (see below) Deployment Status says: 1. Checking Signature 2. Erasing 0x0******* (cant remember exactly) 3. Deploying ER_FLASH 3. Checking Signature 4. Exiting application and the output window of MFDeploy says: "Chk s" and thats it. If i then try to click Target > Device Capabilities, it says "Error: No Response From Device" Ive seen screenshots and this normally says "Checking Signature, "Signature Passed"? Any idea what might be going wrong? Thanks,
Intelligent People Aren't Afraid To Ask For Help.
#67 Chris Walker
Posted 05 July 2011 - 02:12 PM
We changed this in an early version of 4.1.0...so all current versions should have the reduced FAT buffers and updated wording. This should all be checked in with the .NET MF 4.2 beta 1+ firmware as well.
#68 Chris Walker
Posted 05 July 2011 - 02:14 PM
Hi Stuart,
The OneWire support is an add-on. We'll make a version with OneWire when the beta gets farther along (release candidate or RTM). I believe that CW2 is working on some updates, so we'll be sure to include the latest version.
When you reboot the Netduino, are you able to connect? Could you run "Target -> Device Capabilities" and post the results here?
#69 ColinR
ColinR
  • 142 posts
Posted 14 July 2011 - 10:17 PM
3 Exceptions I'm getting on 4.2 BETA 2:
Exception was thrown: System.Exception: System.Version::ToString
When using:
System.Reflection.Assembly.GetExecutingAssembly().GetName().Version.ToString()
Exception was thrown: System.Exception: Microsoft.SPOT.Net.NetworkInformation.NetworkInterface::get_DnsAddresses
When using:
ni.DnsAddresses[0]
Exception was thrown: System.Exception: Microsoft.SPOT.Net.NetworkInformation.NetworkInterface::IPAddressToString
When using:
ni.DnsAddresses[0]
#70 Chris Walker
Posted 14 July 2011 - 10:35 PM
Colin, Did you set your network settings in MFDeploy after flashing the .NET MF 4.2 beta? Chris
#71 ColinR
ColinR
  • 142 posts
Posted 15 July 2011 - 05:14 AM
Colin,
I did, yes. What I didn't do is update the tinybooter - the 4.2 beta looked like it flashed ok though?
The exceptions do not hit every time unfortunately - I can't see a pattern.
#72 Chris Walker
Posted 15 July 2011 - 05:31 AM
Could you please update TinyBooter as well and re-test? That could actually be important here... Chris
#73 ColinR
ColinR
  • 142 posts
Posted 15 July 2011 - 06:39 AM
OK, will update it tonight and re-post.
#74 ColinR
ColinR
  • 142 posts
Posted 15 July 2011 - 08:11 PM
I get the two DNS Address related exceptions still, with the new tinybooter loaded. I've not seen the Version.ToString() again.
#75 Edward
Edward
  • 38 posts
Posted 16 July 2011 - 02:27 PM
I agree, but I'm not an expert of things and like we say in Dutch: "van 't kastje naar de muur". Litteraly: "from the cupboard to the wall" but loosly translated being bounced around.
So perhaps you could reply on that issue, or take some other actions? If you need me to test anything, you know how to contact me ;)
The hang on deployment and the following BSOD on disconnect or reset is driving me crazy; makes serious development an absolute pain. It's happening to me on about 50% of deployments. Is there any known workaround? Is the 4.1 driver better than the 4.2? Is it happening only to a few people or everybody? Only 4 votes on codeplex. I'm using Win7 64bit and VS2010 Pro.
Edward
#76 Stefan
Stefan
    Moderator
  • 1965 posts
Posted 17 July 2011 - 10:12 PM
Hi Edward, I share your pain, I really do. Could you post your findings in http://netmf.codeple...m/workitem/1049 as well, or just vote for that issue? :)
#77 Dan T
Dan T
  • 91 posts
  • LocationBoston (Greater)
Posted 30 July 2011 - 02:00 PM
Edward
It's happening to me. Win7 32bit, VS2010 Express. I'm now the 8th vote on CodePlex.
So weird to see the BSOD. It's been years.
#78 Glen
Glen
  • 26 posts
Posted 30 July 2011 - 04:13 PM
I had it happen a couple times yesterday after going to 4.2 as well.
#79 Edward
Edward
  • 38 posts
Posted 04 August 2011 - 11:52 PM
I just spotted that this issue despite a high vote count was closed on Codeplex this Monday by "lorenzte" with no explanation. Outrageous.
Seriously considering an alternative platform for my product development as NETMF is proving too painful and unproductive at the moment. I had high hopes for it.
#80 Chris Walker
Posted 05 August 2011 - 12:41 AM
I believe he closed the blue screen issue with a note that it may be fixed in RC1 (and to re-open it if it's not).
Can you downloaded the brand new .NET MF 4.2 RC1 SDK and see if you still get the issue (and if so, we'll push to re-open the issue)?
