Netduino Plus 1 Firmware v4.1.0 (update 6)
Posted 02 March 2011 - 12:36 AM
- kekzenevito and AmagmaNub like this
Posted 02 March 2011 - 12:39 AM
- Stefan likes this
Posted 02 March 2011 - 12:44 AM
Posted 18 April 2012 - 05:15 PM
Posted 18 April 2012 - 06:48 PM
Help, I have been trying to get this board to work on the network, all projects will load other than web projects. I originally received "not supported" from the MFDeploy when trying to check the current level. I have downloaded the v4.1.0.zip and deployed the files. The ER_Flash will finish, but the ER_CONFIG does not seem to finish and the "box" does not go away. If I try to cancel, it will not and I actually have to use task manager to kill it. I have been able to read the configuration after restarting but still also get the "not supported". I am powering this only with the usb cable and no other power, the pwr light doesn't flicker when the network cable is plugged in (doesn't seem to loading it down). I have been able to get into network configuration 1 time to change the configuration and am able to ping the board. I have tried 2 different pc's to see if the there might be a problem, both are running xp with the current updates. Unfortunatily this is the only board I have, so I'm unable to see if it is a board problem or the one sitting at the keyboard. I appreciate any direction to make this work properly
Hi newbietoo,
Have you tried resetting the board totally? When I was upgrading firmware I had something similar but it was because I forgot to update the TinyBootloader
http://wiki.netduino...ep-by-step.ashx
Thanks.
Posted 18 April 2012 - 09:48 PM
Hi newbietoo,
Have you tried resetting the board totally? When I was upgrading firmware I had something similar but it was because I forgot to update the TinyBootloader![]()
Thanks.
Posted 18 April 2012 - 09:54 PM
Posted 18 April 2012 - 10:09 PM
That's the chip used on Netduino and Netduino Plus, so you should be good to go.Thanks for the help, should I be concerned that the atmel chip I have is AT91SAM7X512 AU
Posted 18 April 2012 - 10:21 PM
Posted 18 April 2012 - 10:50 PM
If you unplug and reattach your Netduino Plus and you're able to deploy to it...you're all good.Thanks Chris. I'm only seeing Chk signature signature pass repeated twice and the executing Application with the green progress all the way to the right, should the box go away or should I just cancel?
If not, erase the board using the gold erase pad and reflash TinyBooterDecompressor...then flash the NETMF firmware (TinyCLR).
Posted 05 May 2012 - 04:00 PM
Hi newbietoo,
I am planning on trying the update to 4.2.0 and downgrade to the stable 4.1 version before doing any work. However, I have not been able to get any SMB-BA flash utility to work on either of my available windows machines (Win7 Pro x64). The problem is that I can't get the Atmel drivers to install instead of the Netduino drivers so that the utility can recognize the chip and flash it. The OS complains that they are are not 64-bit drivers. Any advice on a work around? I am using SMB-BA 2.11 for reference.
Posted 09 May 2012 - 01:11 PM
Have you tried the instruction I posted here solved all the issues I have ever had with SAMBA not opening or detecting connected boards under x64 windows.
Nak.
Posted 31 May 2012 - 03:40 AM
Posted 18 July 2012 - 12:46 AM
Posted 18 July 2012 - 07:53 AM
No thats a standard part, I think all ND+'s i have ever had my hands on (20 odd) have had that model of chip.
Nak.
Posted 03 October 2012 - 08:38 AM
Posted 03 October 2012 - 02:22 PM
Before doing the compare in SAM-BA, did you add a few zeros to the "size" value? If not, it will only read the first small bit of FLASH and since the size isn't big enough it will give you a verification failure.I'm running SAM-BA 2.12 on Win7-x64, and that works fine. I can do the reset, connect to the Netduino and run the scripts. However, when I flash the bootloader (TinyBooterDecompressor) and then read the file back, there are always differences. Strange thing is, when using the memory spy from the SAM-BA tool, not all errors are visible... I am wondering whether the flash in the Atmel is maybe damaged, or whether there is a problem with the different revisions (EK vs. AU)?
Regarding EK vs AU... -EK means "evaluation kit" and is the name of the main development board for AT91SAM7X512-AU. It uses the same chip as Netduino which is why we use its script to flash the Netduino. Since they both use the same chip, they both flash using the same configuration.
Posted 04 October 2012 - 08:58 PM
Hi Nzc,
Yes, I make sure to read enough bytes to make the comparison. I had a closer look at the data, and it's always the same bit that appears to be 1 when sometimes it should be 0, and only in one memory block. Can it be that the flash memory is corrupt? At least the file I read back is always the same, but different from what I try to write
When I reset gold pad - 3.3V, I can always get back to the CDC connection, and scripts and downloads always run fine, I just don't get the right code in the flash. When reconnecting after the flash, the USB gives a low-level error, and I don't see any info, not even the usual vid/pid stuff.
