OK I'm a convert! After years on the Arduino, VB.Net on a micro ... I'm sold!
I just received my first Netduino Plus 2 and have been impressed but have encountered a three problems that I assume are a result of a bad board.
Problem 1: I had to flash my firmware 6+ times this weekend when the .Net debugger could not connect to the board. I am assuming it's related to problems 2 & 3.
Problem 2. The following results in the Debug statement running. This only happens on Pin 7. All others work as expected.
Dim Port = New OutputPort(Pin.GPIO_Pin7, False)
Port.Write(True)
If Not Port.Read Then
Debug.Print("Error: Station " & Number.ToString & " should be on but Pin(" & Port.Id.ToString & ") is not high")
Endif
Problem 3. The 4th statement below "Dim A4 ..." results in a "A first chance exception of type 'System.ArgumentException' occurred in Microsoft.SPOT.Hardware.dll" error. This only happens with Pin 4.
Dim A1 As OutputPort = New OutputPort(Pin.GPIO_Pin1, False)
Dim A2 As OutputPort = New OutputPort(Pin.GPIO_Pin2, False)
Dim A3 As OutputPort = New OutputPort(Pin.GPIO_Pin3, False)
Dim A4 As OutputPort = New OutputPort(Pin.GPIO_Pin4, False)
Dim A5 As OutputPort = New OutputPort(Pin.GPIO_Pin5, False)
Any help would be appreciated!
Ports on Netduino
Started by Samson, Oct 06 2013 11:11 PM
1 reply to this topic
Posted 09 October 2013 - 07:27 PM
Hi Samson,
Pin.GPIO_Pin# refers to the physical pins on the microcontroller rather than the digital/analog pins on the blue headers.
Try using Pins.GPIO_PIN_## instead. Yes, it's a small difference in spelling--but a huge technical difference that will get you the pins you're looking for.
Using the MCU pins directly can lead to unintended behavior (like locking out the debugger).
