netduino plus 2 compatible gps/gsm module
netduino plus 2 gps gsm
5 replies to this topic
#1 titomc
titomc
Posted 08 September 2013 - 06:42 PM
I have a netduino plus 2 board and I am trying to send gps location with gprs to my server.I am a java programmer by profession,but recently I got interested in IoT and m2m communications.I would like to know if I can use the below shield for the netduino plus 2 , though its mentioned for arduino.I just want to make sure I purchase the right parts.Or if anyone could suggest me the right parts to purchase for my gps+gsm tracking project.
here is the shield which I found that has gps & gsm.
http://www.dfrobot.c...0_(SKU:TEL0051)
#2 Arbiter
Arbiter
  • 132 posts
  • LocationBrisbane, Australia
Posted 09 September 2013 - 06:01 AM
You'll have to write your own drivers.
Most carriers charge outrageously for GSM, making it a very expensive way to do tracking comms. I had a look at the SIM908 chipset and it doesn't appear to support anything newer than GSM. Nor does it surface a connector for an external GPS antenna, which means you will need an IP66 enclosure because you'll have to roof mount it to get a lock in weak signal conditions.
To improve reliability and mitigate operational costs I recommend a store and forward architecture, for which this shield is not an ideal choice.
So far as I can determine, the SIM908 does not support altitude. If altitude matters to you then you need a shield that supports a uBlox 5, 6 or later such as this http://www.dfrobot.c...81#.Ui1kDdV-8dU.
I haven't personally used that one but I do intend to test one at some point.
#3 hanzibal
hanzibal
  • 1287 posts
  • LocationSweden
Posted 09 September 2013 - 08:42 AM
There's the GM862 module from Telit that has it all; GSM/GPRS/3G and GPS. Sparkfun used to carry a breakout for it (retired now) but might still be available from other locations:
https://www.sparkfun...cts/retired/281
EDIT: Found the bare Telit module here:
http://www.electroki...24?currency=USD
For GPS only, I've used the UBlox 6 based module that's cheap and works great:
http://www.ebay.com/...=item2ec7488539
The module comes with a small antenna but there's a uFL connector to support an alternative antenna of your own choosing.
#4 hanzibal
hanzibal
  • 1287 posts
  • LocationSweden
Posted 10 September 2013 - 08:55 AM
Hello again, I just found this complete kit with GM862 module, breakout, antenna, etc:
http://www.skpang.co...-usb-p-414.html
EDIT: Sorry, the kit has been sold out but might be available elsewhere.
#5 nhale
nhale
  • 64 posts
  • LocationHeidelberg, Germany
Posted 10 September 2013 - 09:52 AM
Take a look at these ones.
The Seeedstudio GPRS Shield v2.0 has GSM and GPRS support and you can replace the internal antenna
http://www.seeedstud...tml?cPath=19_20
http://www.seeedstud...PRS_Shield_V2.0
and the Adafruit Ultimate GPS Breakout v3 gives you selectable rates of 1/5/10Hz, the possibility to connect an external antenna and everything on a quite small PCB.
http://www.adafruit.com/products/746
Both work fine with my Netduino and both have the same type of u.FL connector for their antennas.
Have fun
#6 titomc
titomc
Posted 11 March 2014 - 04:04 PM
Sorry for not getting back. I will evaluate each boards and get back with questions.
Also tagged with one or more of these keywords: netduino plus 2, gps, gsm
