Measuring performance.. strange behaviour
#1 Flores
Flores
  • 64 posts
Posted 15 August 2010 - 10:36 AM
I've setup a small program to measure the performance of the netduino:
        static bool state = false;
        static OutputPort led = new OutputPort(Pins.ONBOARD_LED, false);
        static AnalogInput input1 = new AnalogInput(Pins.GPIO_PIN_A0);
        static int analogValue = 0;
        static bool ledstate = false;
        static int counter = 0;
            long start = DateTime.Now.Ticks;
            for (int i = 0; i < 2500; i++)
                analogValue = input1.Read();
                ledstate = !ledstate;
                counter = counter + 1;
                led.Write(ledstate);
            long end = DateTime.Now.Ticks;
            TimeSpan span = new TimeSpan(end - start);
            Debug.Print("timespan: " +span.Milliseconds.ToString() + "ms");
If I run this code, it reports that it took 37ms. But if I comment out the
part it reports that it took 979ms !! Thats strange right?
I increased the for to about 20000, then it reports it took 900ms, but the led is way longer on than a second. So it simply reports the wrong time. But why? Can't figure it out.
#2 Steven Behnke
Steven Behnke
  • 70 posts
  • LocationLas Vegas, NV
Posted 15 August 2010 - 02:33 PM
Is there a TimeSpan.TotalMilleseconds like there is in the full .Net Framework? If not you'll need to add all of the components of the timespan after you multiply them out to get the total.
#3 kingpin2k
kingpin2k
  • 23 posts
  • LocationUSA
Posted 15 August 2010 - 03:37 PM
I'm not sure about the cpu that's on the netduino, but most modern cpu's will queue up instructions in their own order as long as they don't screw up dependencies. So your counter may be irrelevant to the actual performance of the code (especially since nothing depends on it).
For example, a multiplication may take 30 cycles to complete, where as an addition will probably only take 1.
Ex.
counter ++;
othernumber *= 3;
counter = counter + othernumber;
if your cpu ran this exactly how it was written it would go like this
counter++; //1 cycle til complete
othernumber *= 3; //30 cycles til multiplication completes
//29-0 NOOP aka no operation (waiting on multiplication to complete)
counter = counter + othernumber; //now we can do this at the 32 cycle mark
your machine code might swap the order of those two since they run in different area's of the cpu (the adder and the multiplier)
it might do
counter++; //29 cycles til multiplication complete
//28-0 NOOP aka no operation (waiting on multiplication to complete)
counter = counter + othernumber;//now we can do this at the 31 cycle mark
What I'm trying to say is your counter is probably irrelevant, and performance of the netduino based on the speed the light can turn off and on will probably be very skewed :)
Homer: [Meeting Aliens] Please don't eat me! I have a wife and kids. Eat them!
#4 Chris Walker
Posted 15 August 2010 - 04:27 PM
Three quick things:
TimeSpan
As Stephen said, TimeSpan.Milliseconds only returns the Milliseconds component of a TimeSpan. So 1.030s and 4.030s would be return "30".
Execution Time
Different commands take different amounts of time to execute. For example, i++ is pretty quick...but AnalogInput.Read() waits for a hold time, sample time, etc. before returning. A good way to measure execution time of a specific function is:
First, measure your base case... Including the dummyCounter++ ensures that the .NET optimizer does not just skip your loop and set i to 1000 :)
            int dummyCounter = 0;
            // start timer here...
            for (int i = 0; i < 1000; i++)
                dummyCounter++;
            // end timer here...
...then, add your command to measure:
                led.Write(true); // command to measure
                dummyCounter++;
...and then simply subtract the first time from the second time to get your execution time for 1000 cycles of the command.
How to Time
What you really want is a Stopwatch class. Here's one we've written.
System.Diagnostics.Stopwatch class (code compatible with desktop/mobile C# projects):
http://forums.netdui...topwatch-class/
#5 Flores
Flores
  • 64 posts
Posted 15 August 2010 - 04:49 PM
Right. That must be it.. stupid mistake.
I was looking for the Stopwatch Class be couldn't vind it.. so wrote my own (including stupid mistakes)
