Best Answer Graham.fry, 03 September 2013 - 08:03 AM
For anybody that cares
If you having a problem using the hardware DLL in 4.3 (with servos) you need to uninstall all 4.3 sdk's and reinstall 4.2
This fixed my problem
![]() A first chance exception of type 'System.InvalidOperationException' occurred in Microsoft.SPOT.Hardware.dll
Started by Graham.fry, Aug 21 2013 02:15 PM
servo A first chance exception
![]() Best Answer Graham.fry, 03 September 2013 - 08:03 AM
This fixed my problem Go to the full post![]()
1 reply to this topic
Posted 21 August 2013 - 02:15 PM Hi
I am trying to get a servo working I copied this code from the internet when I run it, it fails with the following error
Any help will be appreciated
Thanks in advance
Graham
Attached is the code I am using on a netduino plus2 version 4.2.2
program.cs
using System.Threading; using SecretLabs.NETMF.Hardware.Netduino; using Microsoft.SPOT; namespace MinelectricsV2 { public class Program { static Servo[] servos = new Servo[4]; public static void Main() { //Netduino only has four PWM pins: GPIO_PIN_D5, 6, 9, and 10 servos[0] = new Servo(Pins.GPIO_PIN_D5); servos[1] = new Servo(Pins.GPIO_PIN_D6); servos[2] = new Servo(Pins.GPIO_PIN_D9); servos[3] = new Servo(Pins.GPIO_PIN_D10); while (true) { MoveServos(0); MoveServos(90); MoveServos(180); } } private static void MoveServos(uint angle) { for (int i = 0; i < servos.Length; i++) { servos[i].Angle = angle; } Thread.Sleep(2000); } } }
class.cs
using Microsoft.SPOT.Hardware; using SecretLabs.NETMF.Hardware; namespace MinelectricsV2 { public class Servo { static PWM servo; public Servo(Cpu.Pin pin) { servo = new PWM(pin); servo.SetDutyCycle(dutyCycle: 0); } private uint _angle = 0; public uint Angle { get { return _angle; } set { const uint degreeMin = 0; const uint degreeMax = 180; const uint durationMin = 500; // 480 const uint durationMax = 2300; // 2450 _angle = value; if (_angle < degreeMin) _angle = degreeMin; if (_angle > degreeMax) _angle = degreeMax; uint dur = (_angle - degreeMin) * (durationMax - durationMin) / (degreeMax - degreeMin) + durationMin; servo.SetPulse(period: 20000, duration: dur); } } } }
Posted 03 September 2013 - 08:03 AM Best Answer For anybody that cares
This fixed my problem Also tagged with one or more of these keywords: servo, A first chance exception
1 user(s) are reading this topic0 members, 1 guests, 0 anonymous users | |||||||||||||||||||||||||||
