Lost serial characters
#1 avonwood
avonwood
  • 3 posts
Posted 21 August 2013 - 08:32 AM
Hi
I am using a Netduino PLus 2 with s/w 4.2.2 update 2 and have met a strange problem.
I  am sending a serial message to a device which responds with a reply of 26 characters.
The default baud rate is 115200 on com2. My software continually sends a message to the device waits for a reply and then sends it again.
After about 10 seconds I get a reply but with 1 or 2 missing characters.
I have tried reducing the baud rate but the same problem occurs.
I have been running with a network cable plugged into the netduino ( my code does not use the network ) but if i remove the network cable the problem improves - at 19200 it will then seem to run for 10's of minutes with no problem.
My question :-
Is there a known problem with serial receive?
Is there a known problem with the network interface interfering with serial receive?
Posted 22 August 2013 - 02:58 AM
Hi avonwood,
Have you tried enabling flow control?  My first guess is that a buffer somewhere is being overflown, although we're also not talking about a lot of bytes here...
#3 avonwood
avonwood
  • 3 posts
Posted 22 August 2013 - 07:37 AM
Hi
The device i am trying to connect to does not support flow control.
#4 Yanoch
Yanoch
  • 3 posts
Posted 27 August 2013 - 10:34 AM
Just for testing, remove the event and try to wait for your 26 bytes in a while loop then read it...
#5 avonwood
avonwood
  • 3 posts
Posted 29 August 2013 - 03:16 PM
Hi
Any thoughts on this ???
My only solution at the moment is to abandon using a Netduino if this cannot be solved.
