Which USB to Serial converter should I use with Netduino
netduino usb to serial
6 replies to this topic
#1 Prashant
Prashant
  • 8 posts
Posted 15 August 2013 - 12:38 PM
Hi Guys!!
I want a USB to serial converter which I can use with my Netduino 1. I found one on ebay: http://www.ebay.in/i...2-/290803061413
I don't know whether it will be a good option to go for this adapter with Netduino or not.
Can you please suggest?
#2 martin2250
martin2250
  • 37 posts
  • LocationGermany
Posted 15 August 2013 - 01:40 PM
Hi Prashant,
this one looks totally fine, but since it has no cable, you should get an USB extension cable to connect it.
Greetings.
#3 Prashant
Prashant
  • 8 posts
Posted 15 August 2013 - 01:47 PM
Hi Martin,
Thanks for the reply. It's an adapter, that means it will go directly into the USB port. But I do need M/F cable to connect it to Netduino.
#4 nakchak
nakchak
  • 404 posts
  • LocationBristol, UK
Posted 15 August 2013 - 02:33 PM
Any USB to serial adaptor will do if you just want a com port on your PC.
If however you are trying to a program a mini with it there have been reports of some of the cheaper leads not working, so spend as much as you can afford, other wise a cheap FTDI bare tail lead is ideal as it only has a USB plug at one end and bare wires at the other.
Nak.
#5 Prashant
Prashant
  • 8 posts
Posted 15 August 2013 - 04:32 PM
Thanks Nak for the additional information on mini. :)
#6 NooM
NooM
  • 490 posts
  • LocationAustria
Posted 15 August 2013 - 04:51 PM
i have the chepo cp2102, they al worked well for me (i have 7 or so)
http://www.ebay.com/...=item3a731c735c
btw: for programming the mini on rs232 port i use the cp2102 and an max232 to shift the levels to 12v.
works fine, programming and reflashing
#7 orenduino
orenduino
  • 26 posts
Posted 15 February 2014 - 04:18 PM
Hi
just wanted to add a question (same subject)
I suppose the NETDUINO can communicate with 3.3v communication.
will it work good on 5V also ?
will any ARDUINO shield can work ?
http://www.ebay.com/...item1c2dcbb368
http://www.ebay.com/...=item5d4397cc60
what is the maximum speed of the serial (COM) comminucation ?
Also tagged with one or more of these keywords: netduino, usb to serial
