Upgrading NP to NP2 problem
#1 mrsupe
mrsupe
  • 6 posts
Posted 13 August 2013 - 04:36 PM
I have used Netduino Plus. I simply changed the board with unchanged software configuration.
It seems, that it not working. The same program (own LED blinking) works on NP but does not work on NP2.
I put this line before main loop:
  Debug.Print(m_ticksPerMillisecond.ToString()); In both cases it prints 10000.
Where is the problem?
#2 nakchak
nakchak
  • 404 posts
  • LocationBristol, UK
Posted 14 August 2013 - 10:53 AM
Hi mrsupe
I would need a lot more information than you have provided to be able to help in a meaningful manner, i.e. Source Code, Error Messages and possibly build and deployment output.
That said open your projects properties and check that your project is targeting the 4.2 framework, and that your NP2 is recognised by visual studio.  Also install the latest versions of both the netmf SDK and the secretlabs/netduino SDK (on the downloads page of this site)
#3 mrsupe
mrsupe
  • 6 posts
Posted 14 August 2013 - 03:34 PM
My project is targeting 4.2 framework and also NP2.
VS2010 recognise between NP and NP2.
I have installed all newest software as you recommend.
This is what I got during deployng:
Resolving. The debugging target runtime is loading the application assemblies and starting execution. Ready. 'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:Program Files (x86)Microsoft .NET Micro Frameworkv4.2Assemblieslemscorlib.dll', Symbols loaded. 'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:Program Files (x86)Microsoft .NET Micro Frameworkv4.2AssembliesleMicrosoft.SPOT.Native.dll', Symbols loaded. 'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:Program Files (x86)Microsoft .NET Micro Frameworkv4.2AssembliesleMicrosoft.SPOT.Hardware.dll', Symbols loaded. 'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:Program Files (x86)Microsoft .NET Micro Frameworkv4.2AssembliesleMicrosoft.SPOT.Net.dll', Symbols loaded. 'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:Program Files (x86)Microsoft .NET Micro Frameworkv4.2AssembliesleSystem.dll', Symbols loaded. 'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:Program Files (x86)Microsoft .NET Micro Frameworkv4.2AssembliesleMicrosoft.SPOT.Hardware.SerialPort.dll', Symbols loaded. 'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:Program Files (x86)Microsoft .NET Micro Frameworkv4.2AssembliesleMicrosoft.SPOT.IO.dll', Symbols loaded. 'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:Program Files (x86)Microsoft .NET Micro Frameworkv4.2AssembliesleSystem.IO.dll', Symbols loaded. 'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:Program Files (x86)Microsoft .NET Micro Frameworkv4.2AssembliesleMicrosoft.SPOT.Hardware.PWM.dll', Symbols loaded. 'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:Program Files (x86)Microsoft .NET Micro Frameworkv4.2AssembliesleMicrosoft.SPOT.Hardware.Usb.dll', Symbols loaded. 'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:Program Files (x86)Secret LabsNetduino SDKAssembliesv4.2leSecretLabs.NETMF.Diagnostics.dll', Symbols loaded. 'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:Program Files (x86)Secret LabsNetduino SDKAssembliesv4.2leSecretLabs.NETMF.Hardware.Netduino.dll', Symbols loaded. 'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:Program Files (x86)Microsoft .NET Micro Frameworkv4.2AssembliesleMicrosoft.SPOT.Hardware.OneWire.dll', Symbols loaded. 'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:Program Files (x86)Microsoft .NET Micro Frameworkv4.2AssembliesleMicrosoft.SPOT.Time.dll', Symbols loaded. 'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:Program Files (x86)Secret LabsNetduino SDKAssembliesv4.2leSecretLabs.NETMF.Hardware.NetduinoPlus.dll', Symbols loaded. 'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:Program Files (x86)Secret LabsNetduino SDKAssembliesv4.2leSecretLabs.NETMF.Hardware.dll', Symbols loaded. 'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'c:UsersPeterSDocumentsVisual Studio 2010ProjectsbasebonebasebonebinDebuglebasebone.exe', Symbols loaded. The thread '<No Name>' (0x2) has exited with code 0 (0x0). The thread '<No Name>' (0x4) has exited with code 0 (0x0).
#4 Anthony Glenwright
Anthony Glenwright
  • 71 posts
Posted 23 August 2013 - 04:45 AM
Try swapping out your reference to SecretLabs.NETMF.Hardware.NetduinoPlus for the SecretLabs.NETMF.Hardware.Netduino one.  The new Netduinos all use the same reference so the old "plus" one isn't the right one anymore.
