Quick question about ND+2 Socket
8 replies to this topic
#1 elettrozero
elettrozero
  • 58 posts
Posted 11 August 2013 - 09:15 AM
As far as I tested you cannot have more than 5 open connection to ND+2, do you agree?
Simple code:
Socket serverSocket = new Socket(AddressFamily.InterNetwork, SocketType.Stream, ProtocolType.Tcp);IPEndPoint localEndPoint = new IPEndPoint(IPAddress.Parse("192.168.1.100"), 8080);serverSocket.Bind(localEndPoint);serverSocket.Listen(0);while (true){   Socket clientSocket = serverSocket.Accept();   clientSocket.Send(new byte[] { (byte)'a', (byte)'b', (byte)'c' });}
This way you can telnet the server 5 times and receive abc, the sixth time you won't connect.
What I need is about 10 persistent contemporary connections...is there a way?
#2 cce1911
cce1911
  • 71 posts
  • LocationGeorgia, USA
Posted 21 August 2013 - 12:50 PM
http://msdn.microsof...y/ee434782.aspx
socket.listen(backlog)
backlog = The maximum number of incoming connections that can be queued for acceptance. Try
serverSocket.Listen(10);
#3 elettrozero
elettrozero
  • 58 posts
Posted 21 August 2013 - 05:20 PM
Thanks for replying but that doesn't work. Actually I don't think that is related to queued connections but to concurrent connections. For truth's sake, with the whole code loaded, the ndp2 only accepts 4 connections; 5 with only the code above. That leads my to think that it is about memory availability or something like it.
#4 elettrozero
elettrozero
  • 58 posts
Posted 26 August 2013 - 12:26 PM
Actually I hoped Chris would have answered this...
#5 someengineer
someengineer
Posted 26 August 2013 - 02:07 PM
Hey,
your observed 5 max connections correlate with a define for the lwip stack.
looking into: netduino2firmwareSolutionsNetduinoPlus2lwipselector.h
- the netduino plus 2 uses the small memory profile definitions, which are defined in
netduino2firmwareDeviceCodepalnetNetwork_defines_lwip.h
searching the file, we find:
/* MEMP_NUM_TCP_PCB: the number of simulatenously active TCPconnections. */#define MEMP_NUM_TCP_PCB__min 5
guess this answers the question, increasing that amount and recompiling the firmware should solve that problem..
be aware:  i dont know if you will step on any sideeffects and may have to increase any other buffers relating to this, increasing by 1 or 2 may be harmless.. if you need more, try using the medium lwip stack defines - should be done by changing lwipselector.h
regards
#6 derwissel
derwissel
Posted 27 August 2013 - 07:52 PM
Somehow, my post on my company-account does not get approved for ages now..
however:
your problem with the 5 max allowed connections simply is a define in the lwip stack. havent got the sources at home, but within the firmware, netduino uses something called the "small memory profile" - which includes only 5 listening tcp connections..
so its up to compile your own firmware, if you really need more than 5..
greets
derwissel
#7 elettrozero
elettrozero
  • 58 posts
Posted 29 August 2013 - 08:43 AM
You know, this is really getting frustrating.
When you buy a product you usually receive a certain assistance from seller but int this case most questions are asked via forum and sometimes without an answer.
Since I'm using this Secret Labs's product in production environment I'ma a bit worried (and disappointed) about the sake of my clients which are not going to ask me questions via forum.
The point is: if I need to know the limit of this product I must have an answer or I'll need to go further with other products.
#8 Anthony Glenwright
Anthony Glenwright
  • 71 posts
Posted 30 August 2013 - 05:24 AM
You'll find a good explanation of socket limits here:  http://forums.netdui...imit#entry19680
#9 elettrozero
elettrozero
  • 58 posts
Posted 30 August 2013 - 12:02 PM
Thank you Anthony, I have the picture clear. It was like I supposed.
