Make instance of module static
7 replies to this topic
#1 adam8797
adam8797
  • 22 posts
Posted 24 July 2013 - 01:05 AM
I was having issues with this code:
using System;using GoBus;using Microsoft.SPOT;using Microsoft.SPOT.Hardware;using NetduinoGo;using System.Threading;using SecretLabs.NETMF.Hardware.NetduinoGo;namespace MFConsoleApplication1{    public class Program    {        //notice the static ShieldBase        static ShieldBase shieldBase = new ShieldBase(GoSockets.Socket5);        public static void Main()        {            var ledPort = new OutputPort(shieldBase.Pins.GPIO_PIN_D4, false);            while (true)            {                ledPort.Write(!ledPort.Read());                System.Threading.Thread.Sleep(250);            }        }    }}
It throws this:
An unhandled exception of type 'System.Exception' occurred in GoBusSerialTransport.dll
but this code works fine:
using System;using GoBus;using Microsoft.SPOT;using Microsoft.SPOT.Hardware;using NetduinoGo;using System.Threading;using SecretLabs.NETMF.Hardware.NetduinoGo;namespace MFConsoleApplication1{    public class Program    {        public static void Main()        {            ShieldBase shieldBase = new ShieldBase(GoSockets.Socket5);            var ledPort = new Microsoft.SPOT.Hardware.OutputPort(shieldBase.Pins.GPIO_PIN_D4, false);            while (true)            {                ledPort.Write(!ledPort.Read());                System.Threading.Thread.Sleep(250);            }        }    }}
Why can't I have a static instance of a go!bus module?
A similar exception happened when I tried to use the button (making it static vs not static) except the exception occurred in a different dll (whichever one contains the button)
#2 adam8797
adam8797
  • 22 posts
Posted 24 July 2013 - 01:19 AM
Now Im having another issue. here is my new code:
using System;using GoBus;using Microsoft.SPOT;using Microsoft.SPOT.Hardware;using NetduinoGo;using System.Threading;using SecretLabs.NETMF.Hardware.NetduinoGo;namespace MFConsoleApplication1{	public class Program	{		public static void Main()		{			var shieldBase = new ShieldBase(GoSockets.Socket5);			var pot = new Potentiometer(GoSockets.Socket1);			var blue = new OutputPort(shieldBase.Pins.GPIO_PIN_A3, false);			var green = new OutputPort(shieldBase.Pins.GPIO_PIN_A4, false);			var red = new OutputPort(shieldBase.Pins.GPIO_PIN_A5, false);			int c = 0;			while (true)			{				blue.Write(false);				green.Write(false);				red.Write(false);				if (c == 0) red.Write(true);				else if (c == 1) green.Write(true);				else if (c == 2)				{					blue.Write(true);					c = 0;				}				c++;				Thread.Sleep((int)(1000 * pot.GetValue()));			}		}	}}
Now I receive this error when I create the potentiometer:
A first chance exception of type 'System.ArgumentException' occurred in NetduinoGo.Potentiometer.dll
What is going on here!
#3 adam8797
adam8797
  • 22 posts
Posted 24 July 2013 - 01:39 AM
Well, I figured out why the potentiometer didn't work, there is somthing wrong the port 1 the board. Moved to port two and no issue.
Any ideas, or do you think its faulty?
#4 hanzibal
hanzibal
  • 1287 posts
  • LocationSweden
Posted 24 July 2013 - 08:41 AM
I've never used the Go! but it sounds as if the port is broken. This can happen if you draw to much current in trying to drive too big a load. It has happened to me a couple of times and so I simply avoid using the corresponding ports anymore. Does the port work when used as an input?
#5 eplaksienko
eplaksienko
  • 112 posts
Posted 24 July 2013 - 02:11 PM
Try GO ports 1 and 4, it works either 1-4 or 5-8 right now, Chris can correct me If I am wrong
#6 adam8797
adam8797
  • 22 posts
Posted 24 July 2013 - 04:40 PM
Well, about the bad ports, I just tried this code
...public static void Main(){    var b = new Button(GoSockets.Socket2);    var l = new RgbLed(GoSockets.Socket1);    l.SetColor(255, 0, 0);    l.SetBrightness(1);    b.ButtonPressed += (sender, pressed) => l.SetColor(0, 255, 0);    while (true)    {        Debug.Print("done");    }}
And the button works, so there goes the idea that port one is bad (although when the go! boots up, the led on 1 and 2 only flash, they don't stay solid like the rest)
but my previous code still won't work. Im at a loss here.
#7 NooM
NooM
  • 490 posts
  • LocationAustria
Posted 24 July 2013 - 05:28 PM
while (true){    Debug.Print("done");}
wow that looks mean :D
add s leep 1 at least :D
#8 adam8797
adam8797
  • 22 posts
Posted 24 July 2013 - 05:36 PM
Yeah, I just wanted to make sure it didn't freeze!  :lol:
