[font="calibri, sans-serif;"]Hey, [/font]
[font="calibri, sans-serif;"]I got some big issues with the netduino when I’m unplugging the network cable (To simulate network failure) and after a while (1-2 minutes sometimes more sometimes less) plugging in the network cable again it still won’t connect to the server. [/font]
[font="calibri, sans-serif;"]I have attached 2 files “Debug info.txt” and “Netduino Info.txt”. [/font]
Netduino Info.txt 1.43KB
20 downloads[font="calibri, sans-serif;"] contains all the information about the netduino, firmware and such stuff.[/font]
Debug Info.txt 14.54KB
8 downloads [font="calibri, sans-serif;"] contains information about the program that runs on the netduino and what it is trying to do. The line “Network: False” and “Network: True” is when I unplug the network cable, and plug it in again. You can see that after it write “Network: True” It keeps retrying and get exception with the socket connection.[/font]
private void Connect() { connectThread = null; connectThread = new Thread(() => { try { Print("Creating socket"); Socket socket = new Socket(AddressFamily.InterNetwork, SocketType.Stream, ProtocolType.Tcp); <-- This is where it fails??? Print("Socket created"); socket.ReceiveTimeout = 10000; socket.SendTimeout = 10000; //IPAddress ipAddress = HostnameToIPAdress(ServerHostname); //if (ipAddress == null) IPAddress ipAddress = IPAddress.Parse(ServerIP); EndPoint endpoint = new IPEndPoint(ipAddress, ServerPort); socket.Connect(endpoint); IsConnected = true; this.socket = socket; } catch (Exception e) { Print("Exception: " + e.ToString()); IsConnected = false; } }); connectThread.Start(); int timeout = 0; while (connectThread.ThreadState != ThreadState.Stopped && connectThread.ThreadState != ThreadState.Aborted) { if (timeout > 10) { Print("Timeout! ABORT!"); connectThread.Abort(); IsConnected = false; throw new TimeoutException(); } Thread.Sleep(1000); } connectThread = null; }
[font="calibri, sans-serif;"]I created everything in a thread for being sure it would n[/font][font="calibri, sans-serif;"]ever hang, it’s my own little timeout function.[/font]
[font="calibri, sans-serif;"]As you can see in the log it start failing at this line[/font][font="calibri, sans-serif;"] “[/font][color=#2b91af;][font="calibri, sans-serif;"]Socket[/color][/font][font="calibri, sans-serif;"] socket = [color=#0000FF;]new[/color][/font] [color=#2b91af;]Socket[/color]([color=#2b91af;]AddressFamily[/color].InterNetwork, [color=#2b91af;]SocketType[/color].Stream, [color=#2b91af;]ProtocolType[/color].Tcp);” [font="calibri, sans-serif;"]and I have no idea how to fix that? – I have tried nearly everything, also using the global variable instead of a local, but no difference.? You can see in the log that it stop printing [/font] “[color=#a31515;]Socket created”[/color][font="calibri, sans-serif;"] but just throw an exception [/font]
[font="calibri, sans-serif;"]Log (View the file for more detailed log information):[/font]
[font="calibri, sans-serif;"]A first chance exception of type 'System.Net.Sockets.SocketException' occurred in Microsoft.SPOT.Net.dll[/font]
[font="calibri, sans-serif;"]06/01/2011 00:06:01 : Exception: System.Net.Sockets.SocketException[/font]
[font="calibri, sans-serif;"]The thread '<No Name>' (0x23) has exited with code 0 (0x0).[/font]
[font="calibri, sans-serif;"]06/01/2011 00:06:01 : Reconnect failure[/font]
[font="calibri, sans-serif;"]06/01/2011 00:06:11 : Creating socket[/font]
[font="calibri, sans-serif;"]06/01/2011 00:06:12 : Exception: System.Net.Sockets.SocketException[/font]
[font="calibri, sans-serif;"]The thread '<No Name>' (0x24) has exited with code 0 (0x0).[/font]
[font="calibri, sans-serif;"]I hope you guys can help me solving the problem, because it seems like I’m not the only one seeing this problem. I have been reading a lot about Ethernet problems on the forum, where people have created a watchdog to restart the netduino. But I don’t think that it’s the right way to do it, I want this bug to get fixed instead of creating some code to work around the problem, and I’m sure that it will help a lot of people [/font][font="wingdings;"] [/font]
[font="calibri, sans-serif;"]I can say that the same code is running on Windows and Linux with mono where it is working perfectly. [/font]
[font="calibri, sans-serif;"]Best regards [/font]
[font="calibri, sans-serif;"]Jesper [/font][font="wingdings;"] [/font]
