Reading back all the posts on the Netduino forum , HowTo address the PCF8574 IC. There was no clear answer on this question.
But here it is, found on the GarageLab:
http://garagelab.com...er-with-pcf8574
Started by JoopC, Jul 21 2013 08:45 AM
13 replies to this topic
#1Posted 21 July 2013 - 08:45 AM Reading back all the posts on the Netduino forum , HowTo address the PCF8574 IC. There was no clear answer on this question.
http://garagelab.com...er-with-pcf8574 #2Posted 21 July 2013 - 10:07 AM netmftoolbox has a driver for it also, if you read its datasheet, its a very simple ic (- but still a good one, i like its interrupt, thats makes it good for buttons and stuff) #3Posted 21 July 2013 - 05:54 PM NooM, Yes, i had to look better on the IC too, there is a difference between the PCF8574P and the PCF8574AP
The PCF8574P = address binair : 0100[A1][A2][A3] where the A1 ~ A3 stands for the according pin on the IC Low or High. (hex 0x20 ~ 0x27)
The PCF8574AP = address binair : 0111[A1][A2][A3] where the A1 ~ A3 stands for the according pin on the IC Low or High. (hex 0x38 ~ 0x3F)
For you it is simple to tell your colleagues about programming IC's in shorthand writing ...... but you are a genius when you can transfer your knowledge to Netduino users who can barely plugin there shaver in the electrical outlet, like me. #4Posted 22 July 2013 - 10:36 AM iam no teacher.
and there is so much info about this iC, i googled "pcf8574 netduino" and there are tons of helpfull samples/tutorials (the first is good, the second and 4th )
your adressing is correct. its a very good and common iC for input (for output id use a 74hc595, cos its much much faster..) #5Posted 22 July 2013 - 02:39 PM
Here's a post containing a PCF8574 driver class and I2C bus manager that I've made:
http://forums.netdui...-and-ir-remote/
Please let me know if you have any questions by posting in that thread.
#6Posted 23 July 2013 - 11:47 AM hanzibal: hehe your driver looks like mine
but i have a suggestion: when you handly the interrupt like you do you get an odd number. filter it before to get wich pin actually changed
Attached Files#7Posted 23 July 2013 - 08:07 PM
Well, I suppose there's not all that many ways to do it. I'll have a look at your code to see what you mean regarding pin numbering and interrupts.
#8Posted 25 July 2013 - 08:40 AM When sending a byte to the pcf8574 by example with the value 8 (for PIN 3), ......when PIN 3 is NOT connected (to a led) I get with mybase.read() the value 8 returned. When I connect the PIN to a led, I get with mybase.read() 0 back. Is this correct? I expected allways the value 8 .
#9Posted 26 July 2013 - 06:36 AM I can make my question a lot more simple:
What is the return .READ() value of the pcf8574 after sending a byte with the value 8 ?
Is there a difference in the return value when a led is connected to the corresponding p3 pin ? #10Posted 26 July 2013 - 10:24 AM If I remember correctly, the PCF8574 is quasi bi-directional so by reading a pin you would effectively turn it into an input shutting down the output driver of that pin.
Since the pin is connected to ground via a LED (and presumably a resistor), you would get a logic low when reading the pin. #11Posted 26 July 2013 - 07:29 PM Oké Hanzibal, we have implement the IC in the solar logging program (I am just a member of the team). As soon it is out of beta (with the release of 4.3 SDK) we will place the software on codeplex. Another member of the team has made a CAD scheme of the hardware, maybe you can add some tips.
#12Posted 26 July 2013 - 10:03 PM
You obviously think too highly of me, I can only understand part of the design without knowing more of the application. You could add more decoupling, having a 1uF in paralell with a 100nF to ground close to Vdd on ICs improves noise supression a lot. From my own sorry experience, I always pull down unused pins with some 100k. I see you use resistor networks for pull-ups which saves a lot of space. There seem to be quite a few loose joints here and there (no green ball). I'm not all that an experienced circuit designer but I'm sure your team is.
What does solar logging mean in this context, are you following the sun as it travels across the sky or are you controlling a solar panel in some way?
As for the quasi bidirectionality of the PCF8574, I remembered correctly according to section 7.4 on page 12 in the d/s:
http://www.nxp.com/d...eet/PCF8574.pdf
Note that you should drive an I/O pin high (and thus putting it into a high impedance state) before using the pin as an input by reading from it. In my opinion, this is what makes the IC so versatile.
#13Posted 28 July 2013 - 08:55 AM Hanzibal, with this simple program, you can log ( measure) and visualize everything (like energy consumption, water and gas, solar etc) from a pulse meter or a smart meter utilized with a P1 poort. Also log the temperature with the onewire or tmp36 .
http://en.wikipedia....iki/Smart_meter
https://www.google.n...iw=1144&bih=646 #14Posted 28 July 2013 - 01:25 PM
I don't have smart meter but I've made a light detector that detects pulses coming from a LED indicator on the meter fitted in the electricity central cabinet on the outside of my house. The LED pulses once for every half kW (or so) and my detector transfers the pulse via a 433Mhz radio link to a logger inside the house.
I guess it's similar but only unidirectional and I suppose the meter with the LED indicator is a smart meter but it's owned by the electricity company.
0 user(s) are reading this topic0 members, 0 guests, 0 anonymous users | ||||||||||||||
