Best Answer nakchak, 19 July 2013 - 08:32 AM
You can power the ND fine from the 5v pin, have designed several projects that power the device that way.
As for that breakout board it may be easier for you to use LM7805 5v regulator board can be had for next to nothing, or buy a 5V plug in regulated adaptor then all you would need is a barrel connector to connect your project to power, but if you want it to be battery powered you would be better off having the regulator in your project...
NAk.
