ButtonApp question
Button normally-open
1 reply to this topic
#1 Dr Who
Dr Who
  • 261 posts
  • LocationNYC
Posted 11 July 2013 - 04:13 PM
[font="'lucida sans unicode', 'lucida grande', sans-serif;"]Hello![/font]
[font="'lucida sans unicode', 'lucida grande', sans-serif;"]After successfully restoring my Netduino, see http://forums.netdui...ond/#entry51353 for further details; I then turned towards confirming that all of the other well known applications to work, I then selected the regular button one. The button worn on the regular unchanged Netduino model 1 is in fact advertised in the catalogs for its parts happens to be a normally-open style. However when running the unchanged button code it behaves as a normally-closed one. Here:[/font]
using System;using System.Threading;using Microsoft.SPOT;using Microsoft.SPOT.Hardware;using SecretLabs.NETMF.Hardware;using SecretLabs.NETMF.Hardware.Netduino;/* NOTE: make sure you change the deployment target from the Emulator to your Netduino before running this * Netduino sample app.  To do this, select "Project menu > ButtonApp Properties > .NET Micro Framework" and  * then change the Transport type to USB.  Finally, close the ButtonApp properties tab to save these settings. */namespace ButtonApp{    public class Program    {        public static void Main()        {            // write your code here            OutputPort led = new OutputPort(Pins.ONBOARD_LED, true);            InputPort button = new InputPort(Pins.ONBOARD_SW1, true, Port.ResistorMode.Disabled);            bool buttonState = true;            while (true)            {                buttonState = button.Read();                led.Write(!buttonState);            }        }    }}
[font="'lucida sans unicode', 'lucida grande', sans-serif;"]I say unchanged because as it happens naturally I loaded it into my regular IDE for this, VS2010 Express, the C Sharp one, and told the system to go off and run it. In fact this is my second-go-round with the program as I've just returned to the family and am pursuing a more complicated application. I decided to try out the examples. [/font]
[font="'lucida sans unicode', 'lucida grande', sans-serif;"]Upon reading the description of the code in the book that's supposed to travel with these Netduinos, it is the use of the bang, or exclamation point as a not operator has the button state being interpreted that way. Nice![/font]
Doctor Who
#2 iced98lx
iced98lx
  • 134 posts
  • LocationSouth Dakota
Posted 11 July 2013 - 08:36 PM
Ah, booleans are our friends.
For those that did not keep up with the Dr what he is pointing out is the cleverness of this line:
[color=rgb(0,0,0);font-family:monospace;font-size:13px;]led[/color][color=rgb(102,102,0);font-family:monospace;font-size:13px;].[/color][color=rgb(102,0,102);font-family:monospace;font-size:13px;]Write[/color][color=rgb(102,102,0);font-family:monospace;font-size:13px;](![/color][color=rgb(0,0,0);font-family:monospace;font-size:13px;]buttonState[/color][color=rgb(102,102,0);font-family:monospace;font-size:13px;]); [/color]
Which translates to
Write to the LED (either true or false) the opposite of whatever the state of the button is (true or false)
Also tagged with one or more of these keywords: Button, normally-open
