RGB Led using PWM
RGB Led using PWM
Best Answer tim c, 02 July 2013 - 02:39 PM
There was a naming change between 4.1 and 4.2 and Netduino/N2/N+/N+2. Try the sample in this forum post and see if it works for you:
http://forums.netdui...led-pwm-sample/
http://forums.netdui...-netduinoplus2/
IIRC the change had to do with how you address the PINS.
led_r = new PWM([color=rgb(255,0,0);]PWMChannels.PWM_PIN_D9[/color], 100u, 0u, PWM.ScaleFactor.Microseconds, true);
Tim
#1 Graham.fry
Graham.fry
  • 15 posts
Posted 02 July 2013 - 11:36 AM
Hi
I am trying to get an RGB Led working. I am using some code from the web.
The problem is that every time I deploy it, it comes up with the following error:
A first chance exception of type 'System.InvalidOperationException' occurred in Microsoft.SPOT.Hardware.dll
and then you an not connect any more you need to flash the firmware to be able to do anything.
I am using firm ware 4.2.2.2 and the right SDK 4.2.
I have tried different I/O (4,5,6) and combinations.
I have tested the board with, a basic blinky app and a push button app and all is working
Code sample
using System; //use base classes using System.Threading; //use threading classes using Microsoft.SPOT; //use smart personal objects technology classes using Microsoft.SPOT.Hardware; //use hardware related SPOT classes using SecretLabs.NETMF.Hardware; //use Secret Labs hardware framework using SecretLabs.NETMF.Hardware.Netduino; //use the Netduino specific classes
namespace NCIR01 /// Define the namespace we are in /// {   public class Program   {   public static void Main() /// The Main loop (run at power up) ///   {   PWM rgb1 = new PWM(Pins.GPIO_PIN_D8);   PWM rgb2 = new PWM(Pins.GPIO_PIN_D9);   PWM rgb3 = new PWM(Pins.GPIO_PIN_D10);
  while (true) /// Do Forever ///   { rgb1.SetDutyCycle(100); rgb2.SetDutyCycle(0); rgb3.SetDutyCycle(0);
  } /// Close Forever Loop ///   } /// Close the Main() Loop ///     } /// Close the Program Loop /// } /// Close the Namespace Loop ///
Any ideas would help
Graham
#2 tim c
tim c
  • 31 posts
Posted 02 July 2013 - 02:39 PM   Best Answer
Tim
#3 Graham.fry
Graham.fry
  • 15 posts
Posted 02 July 2013 - 03:04 PM
Thank will try this and let you know
