Main Thread Hangs
7 replies to this topic
#1 banalogic
banalogic
  • 7 posts
Posted 28 June 2013 - 01:53 PM
I discovered an interesting issue while experimenting with Threading.
I have the following Main Program:
            ToogleOutput output0 = new ToogleOutput(Pins.ONBOARD_LED);
            ToogleOutput output1 = new ToogleOutput(Pins.GPIO_PIN_A0);
            ToogleOutput output2 = new ToogleOutput(Pins.GPIO_PIN_A1);
            Thread thread1 = new Thread(output1.Flash);
            Thread thread2 = new Thread(output2.Flash);
            thread1.Start();
            thread2.Start();
            output0.Flash();
ToggleOutput is a simple class I made to toggle an output pin periodically. I tried 2 different methods to toggle:
Method 1 uses Thread.Sleep:
                    Thread.Sleep(500);
                    toogleState = !toogleState;
                    port.Write(toogleState);
Method 2 uses an infinitely loop with a counter. The pin toggles every 3000 iterations:
                int counter = 0;
                    counter++;
                    if (counter > 3000)
                        counter = 0;
I connected two LEDs to pin A0 and A1.  The expected behavior is the onboard LED and the two attached LEDs will flash periodically.
If method 1 is used, everything works fine.
If method 2 is used, The onboard LED will flash for a second or so, then it will stop flashing, while my LEDs connected to A0 and A1 will continue to flash. The observation suggests the main thread will run for a second or so, then the scheduler will give execution cycles to thread 1 and 2, but the main thread was never given any processing cycle back to execute its operation. The workaround is creating a 3rd thread to flash the onboard LED, and in main, put Thread.CurrentThread.Suspend() to suspend the main thread.
Interestingly, if I run the program using method 2 through a debugger with Visual Studio, then everything works fine.
Full test program is attached.
#2 hanzibal
hanzibal
  • 1287 posts
  • LocationSweden
Posted 28 June 2013 - 02:35 PM
The scheduler may have problems switching between threads since they are all running in tight loops. Try yielding briefly in the loop by calling Thread.Sleep(1) once in a while.
#3 Nevyn
Nevyn
  • 1072 posts
  • LocationNorth Yorkshire, UK
Posted 28 June 2013 - 02:37 PM
I think the problem is that your main program loop has exited.  Try using a Thread.Sleep with an infinite timeout just before the end of Main.
#4 hanzibal
hanzibal
  • 1287 posts
  • LocationSweden
Posted 28 June 2013 - 11:56 PM
Since the last thing of Main() is to call output0.Flash() which enters an infinite loop, I don't think Main() ever returns, at least not according to the Program.cs attached where ToggleMethod is set to LoopIteration for all instances of the ToggleOutput class by a static member of the Program class.
#5 banalogic
banalogic
  • 7 posts
Posted 29 June 2013 - 03:52 AM
Hanzibal is right. Main() calls an infinite loop and never exited. The scheduler just never returned to the main thread. The interesting thing is the other threads ran fine. If I move output0.Flash() to a third thread then all the lights flashes simultaneously. So how is the Main Thread different from other threads? Also if I run the code in debug under VS then it behaves properly, despite the lights flash much slower because of the debugger communication. Is this a SDK, firmware or .NET MF defect?
The reason I do not want to put a Thread.Sleep() is I need to monitor the input pins as frequently as possible. My actual project currently only runs under the main thread and the main loop iterates 3 times a ms. As I am adding more functionality to the program multi-threaded application will become much cleaner and easier to maintain, but I can't afford to put a 1ms sleep without changing a lot of code. Is there a way to sleep less, i.e. 1/2 ms?
I also wonder how much performance overhead does the thread scheduler take? i.e If I put 2 loop counters on 2 threads and add the counters together (a+B), vs. one thread with loop counter c.  What is the ratio of (a+B) : c?  I will give it a try when I have time and report.
#6 NooM
NooM
  • 490 posts
  • LocationAustria
Posted 29 June 2013 - 11:10 AM
let me know the results. i bet its way slower, at least 20%
do it like that: first count a variable up for one second in your main thread, than print it.
than count 2 variables up, each in a seperate thread (also one second total, not each thread a second :D ) .. add it and print it :D
iam with nevyn, your main problem is the end of your main thread, in your code there is no loop.
or what does output0.Flash(); do ?
add a: thread.sleep(timeout.infinite); after that.
#7 Anshul
Anshul
  • 50 posts
Posted 08 July 2013 - 05:56 PM
The main thread doesn't end, it goes in an infinite loop because output0.Flash() does the same thing as the other threads, either method 1 or method 2 whichever OP is using.
@banalogic: Have you figured out why the main thread does not get an execution cycles? I've noticed that when my main thread goes into a tight infinite loop (tight = no Thread.Sleep(n) in the loop), it doesn't even respond to the Visual Studio debugger. Only option is to erase the program by going into bootloader mode and then reconnect it to the computer.
#8 ziggurat29
ziggurat29
  • 244 posts
Posted 08 July 2013 - 07:49 PM
it gets some execution before locking up.  A couple things I observed:
*  connecting a scope to the onboard LED
  *  always flashes 8 times before 'locking up' (with code as above)
  *  this in my limited manually executed tests of maybe 20 attempts (tedious!)
*  if the code is running not-locked-up (because of debugger connection)
  *  you can detach the debugger (with the 'stop' button)
  *  even close VS
  *  continues to run
and I'm sure everyone has noticed that the flashing of the onboard led is much much faster with no debugger (before it locks up).
I did verify that all the threads are running at priority 'normal'  (although even if they were at different priorities, that should not starve a thread, and I have coincidentally verified that in a separate test in the past, but not relative to the main thread).
Anyway, I think for most folks the underlying problem is masked, because either they are sleep'ing at some point, or do a sleep(infinite) on the main thread, and do all their stuff in the workers.
