Sending data to Xively
Xively cosm netduino_plus_2
#1 o0Higgy0o
o0Higgy0o
  • 3 posts
Posted 13 June 2013 - 03:35 PM
Now that cosm has become Xively I decided to change my temperature senser feed over to xively rather than have it as a legacy cosm feed. I had some initial issues getting the PUT request right to send my temperature data for logging, but finally got it working. So to help anyone wanting to change to xively you will need to firstly set up a new feed and get a new ID and ApiKey. To send the data the DNS lookup is:
IPHostEntry entry = Dns.GetHostEntry("api.xively.com");
or to hard code the IP address:
IPAddress remote_IP = IPAddress.Parse("216.52.233.120");
Host is api.xively.com
All the rest is as it was for cosm.
Here is my temperature sensing and basic socket sending code.  I used socket sending as I wanted to understand the basics of sending the put request. I have copied other peoples code in parts which has been very helpful and appreciated.
using Microsoft.SPOT;using Microsoft.SPOT.Hardware;using SecretLabs.NETMF.Hardware.Netduino;using System;using System.Net;using System.Net.Sockets;using System.Text;using System.Threading;namespace XivelyTemperature{    public class Program    {        const string ApiKey = "Your Key;        const string FeedId = "Your Feed Id";        const string UserAgent = "Xively Netduino Plus 2 Example"; // user agent is the project name        const string CRLF = "rn";        const double VoltsPerDegree = 0.01;        const double OffsetVolts = 0.5;        const double MaxVoltage = 3.3;        const uint MaxAdcValue = 4096;        // wait 10 mins between samples        const int SamplingPeriod = 60000;        const int ConnectionTimeout = 1000;        // if you don't want to use DNS (and reduce your sketch size)        // use the numeric IP instead of the name for the server:        static IPAddress remote_IP = IPAddress.Parse("216.52.233.120");    // numeric IP for api.xively.com        static OutputPort ledPort = new OutputPort(Pins.ONBOARD_LED, true);        static AnalogInput tempInPort = new AnalogInput(Cpu.AnalogChannel.ANALOG_0);        static Timer watchdog = null;        static TimerCallback timerDelegate = new TimerCallback(TimesUp);        const int WatchdogTime = 10000;        static Socket serversocket = null;        public static void Main()        {            IPEndPoint remoteEndPoint = new IPEndPoint(remote_IP, 80);            // use this if you want to use DNS lookup to get IP Address rather than hard code it            //IPHostEntry entry = Dns.GetHostEntry("api.xively.com");            //IPAddress address = entry.AddressList[0];            //IPEndPoint remoteEndPoint = new IPEndPoint(address, 80);            int rawValue;            double temperature;            string temp;            while (true)            {                try                {                    WaitUntilNextPeriod(SamplingPeriod);                    ledPort.Write(true);                    // start watchdog timer for SendData                    watchdog = new Timer(timerDelegate, null, WatchdogTime, Timeout.Infinite);                    Debug.Print("time: " + DateTime.Now);                    //Debug.Print("memory available: " + Debug.GC(true));                    rawValue = tempInPort.ReadRaw();                    Debug.Print("Raw value: " + rawValue.ToString());                    temperature = GetTempFromRaw(rawValue);                    temp = "Temperature, " + temperature.ToString("f");                    Debug.Print(temp);                    SendData(remoteEndPoint, temp);                    ledPort.Write(false);                }                catch (Exception ex)                {                    Debug.Print(ex.Message + " " + ex.StackTrace);                }                finally                {                    // Stop the timer                    watchdog = null;                    // garbage collect                    Debug.GC(true);                }            }        }        /// <summary>        /// send data to xively        /// </summary>        /// <param name="remoteEndPoint">endpoint to send data to</param>        /// <param name="temperature">string parameter to send</param>        private static void SendData(IPEndPoint remoteEndPoint, string temperature)        {            serversocket = new Socket(AddressFamily.InterNetwork, SocketType.Stream, ProtocolType.Tcp);            serversocket.Connect(remoteEndPoint);            // calculate the length of the sensor reading in bytes:            int ContentLength = temperature.Length;            string WholePacket = string.Empty;            // send the HTTP PUT request:            WholePacket += "PUT /v2/feeds/" + FeedId.ToString() + ".csv HTTP/1.1rn";            WholePacket += "Host: api.xively.com" + CRLF;            WholePacket += "X-ApiKey: " + ApiKey + CRLF;            WholePacket += "User-Agent: " + UserAgent + CRLF;            WholePacket += "Content-Length: " + ContentLength.ToString() + CRLF;            // last pieces of the HTTP PUT request:            WholePacket += "Content-Type: text/csv" + CRLF;            WholePacket += "Connection: close" + CRLF;            WholePacket += CRLF;            // here's the actual content of the PUT request:            WholePacket += temperature + CRLF;            byte[] buffer = Encoding.UTF8.GetBytes(WholePacket);            serversocket.Send(buffer);            bool poll = serversocket.Poll(1000000, SelectMode.SelectRead);            if (serversocket.Available > 0)            {                buffer = new byte[serversocket.Available];                serversocket.Receive(buffer);                string resp = new string(Encoding.UTF8.GetChars(buffer));                Debug.Print(resp);            }            serversocket.Close();        }        /// <summary>        /// convert the raw ADC value to real temperature        /// </summary>        /// <param name="rawValue">int ADC value</param>        /// <returns>double real temperature</returns>        private static double GetTempFromRaw(int rawValue)        {            double voltsValue = (rawValue * MaxVoltage) / MaxAdcValue;            return (voltsValue - OffsetVolts) / VoltsPerDegree;        }        /// <summary>        /// sleep to next sample time        /// </summary>        /// <param name="samplingPeriod">time to sleep for</param>        private static void WaitUntilNextPeriod(int samplingPeriod)        {            long now = DateTime.Now.Ticks / TimeSpan.TicksPerMillisecond;            var offset = (int)(now % samplingPeriod);            int delay = samplingPeriod - offset;            Debug.Print("sleep for " + delay + " msrn");            Thread.Sleep(delay);        }        /// <summary>        /// watchdog event to run when it kicks in        /// </summary>        /// <param name="state">object passed to method</param>        private static void TimesUp(object state)        {            Debug.Print("Watchdog kicked in");            PowerState.RebootDevice(true);        }    }}
cheers
#2 iced98lx
iced98lx
  • 134 posts
  • LocationSouth Dakota
Posted 11 November 2013 - 02:48 PM
Hat Tip, Mate. They push using HTTPS (yuck) or sockets now-a-days, you wouldn't happen to have updated yours to do it via sockets have you?
#3 iced98lx
iced98lx
  • 134 posts
Posted 12 November 2013 - 03:35 AM
BTW using your work as the basis for this: http://forums.netdui...y-helper-class/
#4 JoopC
JoopC
  • 148 posts
Posted 12 November 2013 - 06:49 PM
You do not need to reset when the Netduino hangs while it's try to send data to a provider. (the well known network bug).
Put the "sending to Xiverly" procedure in a seperate thread, when the thread hangs, (the timer is fine)  simple dispose the thread.
(Thread.abort and thread.dispose) It is more safe then resetting your Netduino and it works well.
