Is it possible to have Date and Time from netduino plus using ethernet interface?
Date from netduino plus
Posted 13 June 2013 - 09:22 AM
Posted 13 June 2013 - 10:45 AM
Perhaps I don't understand but assuming you mean like sending Datetime.Now from N+ to another networked device, what could stop you from doing that?
Posted 13 June 2013 - 05:07 PM
or maybe setting the boards date time from a sever accessed through the ethernet? like NTP?
If so, here's at least one impl I came across:
http://www.jaypm.com...-automatically/
Posted 13 June 2013 - 09:46 PM
I need in a NP [color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;font-size:14px;]Date and Time also after that NP is power off and power on.[/color]
Posted 14 June 2013 - 06:19 AM
Could you please explain in more detail, what you need to do exactly and why, perferably with a brief description of the overall purpose and goal of your project. One-liners tend to be cryptic, especially since english might not be you first language.
Posted 06 August 2013 - 12:03 PM
Here is the code to get time from the internet using netduino
using System.Net;
using System.Net.Sockets;
namespace GetTime
var result = UpdateTimeFromNtpServer("time.nist.gov", 2); // gmt + 2
Debug.Print(result ? "Time successfully updated" : "Time not updated");
Debug.Print("netduino Time is: " + DateTime.Now.ToString());//TimeClient.LocalDate.ToString());
Thread.Sleep(60000);
//return result;
public static bool UpdateTimeFromNtpServer(string server, int timeZoneOffset)
try
var currentTime = GetNtpTime(server, timeZoneOffset);
Microsoft.SPOT.Hardware.Utility.SetLocalTime(currentTime);
return true;
catch
return false;
private static DateTime GetNtpTime(String timeServer, int timeZoneOffset)
// Find endpoint for TimeServer
var ep = new IPEndPoint(Dns.GetHostEntry(timeServer).AddressList[0], 123);
// Make send/receive buffer
var ntpData = new byte[48];
// Connect to TimeServer
using (var s = new Socket(AddressFamily.InterNetwork, SocketType.Dgram, ProtocolType.Udp))
// Set 10s send/receive timeout and connect
s.SendTimeout = s.ReceiveTimeout = 10000; // 10,000 ms
s.Connect(ep);
// Set protocol version
ntpData[0] = 0x1B;
// Send Request
s.Send(ntpData);
// Receive Time
s.Receive(ntpData);
// Close the socket
s.Close();
const byte offsetTransmitTime = 40;
ulong intpart = 0;
ulong fractpart = 0;
for (var i = 0; i <= 3; i++)
intpart = (intpart << 8) | ntpData[offsetTransmitTime + i];
for (var i = 4; i <= 7; i++)
fractpart = (fractpart << 8) | ntpData[offsetTransmitTime + i];
ulong milliseconds = (intpart * 1000 + (fractpart * 1000) / 0x100000000L);
var timeSpan = TimeSpan.FromTicks((long)milliseconds * TimeSpan.TicksPerMillisecond);
var dateTime = new DateTime(1900, 1, 1);
dateTime += timeSpan;
var offsetAmount = new TimeSpan(timeZoneOffset, 0, 0);
var networkDateTime = (dateTime + offsetAmount);
return networkDateTime;
Posted 21 August 2013 - 12:56 PM
I used the DS1307 real time clock from Adafruit: http://www.adafruit.com/products/264
