NP1 Ethernet Receive Buffer
#1 Bernd
Bernd
  • 39 posts
  • LocationGermany
Posted 03 June 2013 - 03:34 PM
Hello,
does anybody know the size of the Transmit and Receive buffer of the NP1 ? I want to communicate via UDP with the NP1. The UDP packet has 512byte and so I  wonder this will work, or I have to take care to send only packets that are not larger as the receive buffer.
I read the documentation of the ARM7, but I don't understand the relationships of the fifo buffer with 28byte to the receive buffer. The receive buffer consist of several buffers with a length of 128byte. But how does this buffer communicate with the fifo buffer ?
#2 ziggurat29
ziggurat29
  • 244 posts
Posted 03 June 2013 - 11:14 PM
I don't think the ethernet has a buffer per se like, for instance, the serial port.  Looking at the source, the packet buffers are allocated as needed via netbuf_alloc(), which takes a size parameter.
IP fragmentation will handle reconstituting your UDP datagram up to it's max size (64k), from the much smaller IP fragments.  Obviously, achieving that maximum will be a stretch for the netduino, but my point is that limit is a soft limit.  I would think you'd be fine with a couple K, and it would be interesting to hear results from some practical tests.
#3 Bernd
Bernd
  • 39 posts
  • LocationGermany
Posted 04 June 2013 - 08:49 PM
Ok
Thanks ziggurat29 for your fast answer. I have googled about the netbuff_alloc() and I think you are right. At the moment I am very busy but than I have free time, I will make some tests about that with different size of packets. I will give you a feedback.
