Code Help
Pulse width modulation in 4.3
Best Answer Chris Walker, 04 June 2013 - 08:05 PM
Hi Bradski, .NET MF 4.3 has new integrated PWM classes, but we provide backwards-compatibility classes as well. Here's what you need to do: 1. Add "SecretLabs.NETMF.Hardware.PWM.dll" as an assembly to your project references. 2. Add the text "SecretLabs.NETMF.Hardware." before "PWM" when you initialize your PWM objects. Does that get you up and running alright? Chris Go to the full post
#1 Bradski
Bradski
  • 14 posts
  • LocationUSA
Posted 01 June 2013 - 05:58 PM
Anyone have any suggestions on this code to run on the new 4.3 version plus2
using System.Net;
using System.Net.Sockets;
using System.IO.Ports;
namespace NetduinoRobot
            uint watchdogTimer = 200;
            PWM leftDrive = new PWM(Pins.GPIO_PIN_D5);
            PWM rightDrive = new PWM(Pins.GPIO_PIN_D6);          ??
            Socket receiveSocket = new Socket(AddressFamily.InterNetwork, SocketType.Dgram, ProtocolType.Udp);
            receiveSocket.Bind(new IPEndPoint(IPAddress.Any, 4444));
            byte[] rxData = new byte[10]; // Incoming data buffer
            while (true) /* Main program loop */
                /* Try to receive new data - spend 100uS waiting */
                if (receiveSocket.Poll(100, SelectMode.SelectRead))
                    int rxCount = receiveSocket.Receive(rxData);
                    watchdogTimer = 0;
                if (watchdogTimer < 200)   // Only enable the robot if data was received recently
                    // 900 (full rev) to 2100 (full fwd), 1500 is neutral
                    leftDrive.SetPulse(20000, map((uint)rxData[0], 0, 255, 900, 2100));
                    rightDrive.SetPulse(20000, map((uint)rxData[2], 0, 255, 900, 2100));   ???
                    watchdogTimer++;
                else
                    // Disable the robot
                    leftDrive.SetDutyCycle(0);
                    rightDrive.SetDutyCycle(0); ????
        public static uint map(uint x, uint in_min, uint in_max, uint out_min, uint out_max)
            return (x - in_min) * (out_max - out_min) / (in_max - in_min) + out_min;
Posted 04 June 2013 - 08:05 PM   Best Answer
#3 Bradski
Bradski
  • 14 posts
  • LocationUSA
Posted 04 June 2013 - 11:26 PM
That did the trick! Thanks you are the Master!
#4 AarifSaiyed
AarifSaiyed
Posted 03 March 2014 - 01:49 AM
Could i please have the signature of the SecretLabs SetPulse method
#5 Bradski
Bradski
  • 14 posts
  • LocationUSA
Posted 06 March 2014 - 03:34 AM
  private static void Driveline()
            SecretLabs.NETMF.Hardware.PWM leftTrack = new SecretLabs.NETMF.Hardware.PWM(Pins.GPIO_PIN_D5);
            SecretLabs.NETMF.Hardware.PWM rightTrack = new SecretLabs.NETMF.Hardware.PWM(Pins.GPIO_PIN_D6);
____________________________________________________________________________________________________
                    leftTrack.SetPulse(20000, map((uint)rxData[0], 0, 255, 1200, 1800));
                    rightTrack.SetPulse(20000, map((uint)rxData[2], 0, 255, 1200, 1800));
