Our sump pump room is in the corner of a "game room" in our basement. I want to ensure the door stays closed and people (mainly kids) aren't going in there. The "door alarm" solutions commercially available seem targeted at freezers and just didn't suit my needs. Enter Netduino.
My original desire was something that would sound a short alert when the door was opened and then alert at intervals (every few minutes) similar to a smoke detector with a dying battery until the door was closed. After playing around with the Netduino Plus 2 the project has evolved into something that is probably overkill but I thought was cool and wanted to share
The unit monitors the door via a magnetic switch. When the door is opened several things happen:
1. The overhead light is turned on via a high-voltage relay.
2. A webservice is called which sends an MMS to my phone.
3. A timer is activated which will produce and audible alert and antoerh webservice call (MMS message) if the door remains open for a specified period of time.
When the door is closed the light is turned off and the alarm timer is stopped. I've incorporated a 2-line LCD for messages, 2 LEDs (1 for power, 1 for trouble/override mode indication), and some buttons. Strickly speaking the button count could be reduced but I had them and it was easier to program for single function buttons versus programming for short/long press or some time of menuing system (such as many printers use).
Anyway attached is a picture
doormanager.JPG 28.35KB
36 downloads, a wiring diagram
Netduino_Door_Manager.png 30.99KB
34 downloads, and the C# project
DoorManager.zip 8.78KB
38 downloads. Feel free to make fun of my neophitic soldering/wiring job, I'm not very experienced in that art
My next step is to add a water level sensor and battery backup but that will have to wait for another day.
Netduino Door Alarm
- Turns light on automatically when door is opened and off when door is closed
- MMS alert when door is opened (via web service call)
- Audible alert and additional MMS alert if door is left open longer than the timer
- Alerts repeat at specified intervals if door continues to be left open
- Button 1: Manual light on/off override
- Button 2: Return to automaticaly light control
- Button 3: Review error messages (mainly for network connections)
- Button 4: Turn on/off door sensor (allows for prolonged door open without alerts)
Parts list:
Netduino Plus 2 - $59.95
http://www.amazon.co...uct/B009QOYK2U/
Magnetic Switch - $4.60
http://www.amazon.co...uct/B0009SUF08/
Amprobe RC-120S Remcon Relay Switch - $39.33
http://www.amazon.co...uct/B0029XOKH0/
9V Power Adapter - $6.45
http://www.amazon.co...uct/B003XZSZWO/
Parallax 2x16 Serial LCD w/Speaker - $29.99
http://www.parallax....50/default.aspx
5VDC/1A SPDT Micro Relay - $4.69
http://www.radioshac...oductId=2062480
1N4004 Micro 1-Amp Rectifier Diode - $1.49
http://www.radioshac...oductId=2036270
MPS2222A Transistor - $1.49
http://www.radioshac...oductId=2062608
3 1K-Ohm Resistors - $1.49
http://www.radioshac...oductId=2062323
2 LEDs, 4 Momentary Switches, misc screws, project box
Optional:
Protoshield Kit for Ardiono - $9.90
http://www.seeedstud...uino-p-318.html
This kit includes a prototyping circuit board, connectors, resistors, LEDs (not project box mountable), switches (not project box mountable) and other misc parts that can help an initiate get started.
