I2C LCD not working on Netduino Plus 2
19 replies to this topic
#1 Anthony Glenwright
Anthony Glenwright
  • 71 posts
Posted 23 May 2013 - 07:50 AM
I am trying to get an I2C LCD working with my ND Plus 2.  This is an ongoing project that has been running successfully on an original Netduino Plus "1".
  • The LCD, SCL/SDA pullups (4.7k) and some other buttons, etc for my project are all part of a prototype shield
  • The shield and software works fine on my ND Plus ("1" not 2).  That is, the exact same shield, LCD and software.
  • I have jumpered the new SCL/SDA pins to A4/A5
  • I am using firmware v4.2.2.2 on the ND2 Plus
I2C.Execute is returning 0 every time it gets called.  The rest of the application appears to be running OK (just no LCD output!).  Is there something else I need to do to migrate my I2C functionality from the original ND Plus to the "2" (other than the new I2C pins, that is)
The LCD is a DFRobot I2C/TWI LCD1602 (like this)
#2 Bi Qin
Bi Qin
  • 23 posts
Posted 23 May 2013 - 09:04 AM
well,for NP2+,you should connect I2C bus to the SCL/SDA pin?not A4/A5.
A4/A5 on NP2+ is PC4/PC5 on STM32F405,if you look into the datasheet,neither of them got I2C function,you can just  use them as ADC input pin.
#3 Anthony Glenwright
Anthony Glenwright
  • 71 posts
Posted 24 May 2013 - 03:07 AM
Thanks for your reply, but have already jumpered the new SCL/SDA pins to A4/A5, so it should be working.
#4 Bi Qin
Bi Qin
  • 23 posts
Posted 24 May 2013 - 03:03 PM
If possible,I would suggest you to measure the waveform of the I2C bus to see if anything abnormal.
#5 ziggurat29
ziggurat29
  • 244 posts
Posted 24 May 2013 - 03:51 PM
I second bi qin's suggestion of taking an actual look at the waveform.  I want to add this from my recent experience if it's  useful:
*  I was needing a ds1307, and put it on the special sda/scl lines.  what could be simpler, right?  well it didn't work
*  I fiddled with it for quite a while but miraculously my scope arrived later that day.  guess what -- no output whatsoever.  hmm.
*  I flashed my NP2 with firmware 4.2.1.2, and guess what?  worked perfectly.
*  I flashed back to 4.2.2.1, and it failed.  Hmm
Ultimately in my case, I had to hook my device to the a4/a5 and bitbang i2c (I have an in-between shield that does not pass through the newer pins), which also worked fine for me, and so I haven't gotten back to looking at the firmware issue.
so, do look at the waveform -- it might not be you.
#6 yogotie
yogotie
  • 16 posts
Posted 27 May 2013 - 03:11 AM
I found some odd issues with I2C logic in the controller used for the NP2+.  The I2C state machine in this part has a locking condition, which is stated in the datasheet and errata for this part, but without and debugger and a scope it can be hard to determine if this is the issue.  I did verified that this is in fact a real issue with the latest firmware, thanks to ziggurat29's posts about how to compile the source.
http://forums.netdui...c-lockup-issue/
#7 hanzibal
hanzibal
  • 1287 posts
  • LocationSweden
Posted 27 May 2013 - 01:46 PM
Perhaps I'm missing the point here, but why are you at all bridging the I2C pins - is it because you use some kind of shield with fixed wiring?
If you're otherwise not using A4/A5 from your Netdino, they could easily be in a default configuration where they have a strong negative effect on the I2C data line. You could try configuring them as digital inputs and see if that helps.
#8 ziggurat29
ziggurat29
  • 244 posts
Posted 27 May 2013 - 02:39 PM
...The I2C state machine in this part has a locking condition, which is stated in the datasheet and errata for this part, but without and debugger and a scope it can be hard to determine if this is the issue.  I did verified that this is in fact a real issue with the latest firmware...
Mmm! thanks, yogotie, for figuring that out and reporting it, along with your change to fix it.  To bad we don't have a process by which to submit patches (or even a reliable way to get the current and historic firmware source).
#9 Anthony Glenwright
Anthony Glenwright
  • 71 posts
Posted 27 May 2013 - 11:29 PM
A4/A5... is it because you use some kind of shield with fixed wiring?
In a sense, yes.  I have a shield based on a arduino protoshield, which I made for use with the original netduino plus.  My application ended up running out of memory, and then right on cue, along came the plus 2.  So I am using a board that was made for the old layout.
... bi qin's suggestion of taking an actual look at the waveform
I don't have an oscilloscope so I cannot test anything with that.  I have decided to make a new shield and use Mario's design (here: http://tinyclr.it/th...lcd-module.aspx), which uses straightforward digital I/O on the netduino rather than I2C.  As a plus, since it uses a shift register IC, I end up with a design with an LCD that I can buy for $3 instead of a $15 I2C one.
If you're otherwise not using A4/A5 from your Netduino, they could easily be in a default configuration where they have a strong negative effect on the I2C data line. You could try configuring them as digital inputs and see if that helps.
 I will give that a try, as it would be good to know if it works, even though I am going to use the shift register solution.
Thanks all for your suggestions.
#10 hanzibal
hanzibal
  • 1287 posts
  • LocationSweden
Posted 28 May 2013 - 12:37 AM
Yes, Mario's SPI driven LCD Boost library using s shift reg is probably the badest boy in town right now. It would be nice if you came back with a post on how that turns out for you. I've been looking to use his lib myself one of these days...
#11 iced98lx
iced98lx
  • 134 posts
  • LocationSouth Dakota
Posted 28 May 2013 - 02:38 AM
FYI, I got a very similar one to work, using this post: http://forums.netdui...-i2c-interface/
I changed up the driver ever so slightly to use NooM's i2c method, set a few things public and I can now write without a problem on my N+2 with the latest firmware. I have a couple i2c devices on the bus (the LCD and a PWM controller) but now that the LCD works the PWM doesn't appear to be working.
EDIT: Whichever device I call first seems to work, haven't gotten'em both working on i2c. Figures.
EDIT # 2 - Seems to be a timing + voltage spike when the power supply turns on + threading issue, probably can all work together fine.
#12 Bi Qin
Bi Qin
  • 23 posts
Posted 04 June 2013 - 02:32 AM
I've got an I2C LCD recently,and it's not working either.The label on the bottom of the PCB is"YwRobot LCM1602 IIC V1".
But the reason is found::There is no pull up resistor For I2C Bus on the LCD module.
So,might there be some different on I2C design between NP1+ and NP2+?Which makes NP1+ don't need external pull up resistor.
I've try to draw the schematic for that I2C To IO board and add pull up resistor later by myself.Wait for my update.
#13 Bi Qin
Bi Qin
  • 23 posts
Posted 04 June 2013 - 03:51 AM
OK,confirmed that add 2 pull up resistors will make I2C To IO expander work.I've draw a schematic for that board for your reference.Attached File  lcm1602.pdf   93.6KB   125 downloads
#14 Bi Qin
Bi Qin
  • 23 posts
Posted 06 June 2013 - 04:47 AM
I've already make an I2C 1602 LCD working with my netduino plus2:
http://lifetyper.com/post/52202466954
#15 Anthony Glenwright
Anthony Glenwright
  • 71 posts
Posted 11 June 2013 - 05:28 AM
Thanks Qi, my original board already had pullups on the I2C lines.  I have gotten the shift register to work OK, took a little while because I had accidentally swapped the wire from the shift register MR pin & R4 (they were each connected to the wrong wire on the transistor).  Once I figured that out it worked straight away :-)
Here's the fritzing diagram for those who are interested.  The shift register part is 100% based on Mario's breadboard layout here.
The resistors on the protoshield board and accompanying headers on the stripboard are pullups for three pushbuttons used to control a menu on the LCD, so if all you are doing is making an LCD you can ignore them.
This layout is definitely not the best, there are a number of mistakes which I will eventually need to fix:
    [*]The LCD has a female header block soldered onto the bottom which connects to the male header block at the right-hand side, which means the contrast adjustment is underneath the LCD!  I may end up just soldering the pot to the bottom of the board on my next revision (or move it).
    [*]There are a few more wires (the yellow ones) then there needs to be, on my next revision I will try to line up the LCD control wires with Q4,5,6 on the shift register to make it a little simpler.
    [*]And of course the board is fairly widely spaced out as its a version 1, it could be a little more compact.  Hopefully I can squeeze it into a protoshield size eventually.
    [/list]
#16 hanzibal
hanzibal
  • 1287 posts
  • LocationSweden
Posted 11 June 2013 - 06:17 AM
Nice work! Everybody seem to use a potentiometer for brightness and/or contrast. Why not use PWM instead? Sure, it eats two more pins but personally I find it more elegant and you could easily implement ambient light auto-compensation with a photoresistor wired to the ADC.
#17 Bernd
Bernd
  • 39 posts
  • LocationGermany
Posted 16 June 2013 - 02:08 PM
I use the NP2 and the V4.2.2.2. If I get it right, I have to use a pull up resistor on both wire to the positive potential. The I2C Output is 3.3V . Can i connect the pull ups to 5V or is it still better to connect the resistors to 3.3V ? ******* I just found a thread in the board that answer my question. So i think the Outputs are in the Open Collector mode and so the high signal must generate via pull up resistors. So I can pull up to 5V. I think this must be fine
#18 Anthony Glenwright
Anthony Glenwright
  • 71 posts
Posted 17 June 2013 - 07:13 AM
RE PWM: Wouldn't PWM only supply up to 3.3v?  So you could only set the contrast from 0-3.3V instead of the full range 0-5V?
#19 hanzibal
hanzibal
  • 1287 posts
  • LocationSweden
Posted 17 June 2013 - 11:16 AM
Yes, brightness will be slightly dimmer than it would with 5V but it's still bright enough. Contrast is "active low" so no problem there.
#20 gabesilva
gabesilva
  • 3 posts
Posted 20 June 2013 - 06:23 AM
I just got ND+2 and SainSmart IIC/I2C/TWI Serial 2004 LCD but am having problems getting it to work. My wiring diagram between the LCD and ND+2 is pretty simple: Vcc -> 5V, Gnd -> Gnd, SDA -> SD and SCA -> SC. I did not tie the A4 and A5 pins though. Do I have to do that? Also do I need pullup resistors for the SDA and SCA connections? I use the LCD library from http://microliquidcr...l.codeplex.com/ but no luck. If anyone has successfully get the ND+2 and said LCD to work, please help me by sending your wiring diagram and sample code with the library that you use. Many thanks.
