MicroSD Card File Lost/Corrupted?
SD NP2+ FileSystem
#1 Bi Qin
Bi Qin
  • 23 posts
Posted 20 May 2013 - 08:26 AM
Hello everyone.
I tried to create&write&read files with micro sd card on NP2+,using a 2gb sandisk micro sd card with FAT format.
From the debug output information,I can see that file did created and exist.But when I remove the card from NP2+ and try to read the content from my PC,I found nothing,sometimes file exist but corrupted.
Even not removing the card, just re-deploy the same code again(as the chip will reboot),the file created last time  disappered(I detect whether file exist before I create it).
After adding a 1000ms sleep,the situation improves just a little bit,which means if I write it for several times, I may get one time success saved.
So,is there anything wrong with my code or any tricks for NP2+ micso sd file write?
using System; using System.Net; using System.Net.Sockets; using System.Threading; using System.IO; using Microsoft.SPOT; using Microsoft.SPOT.Hardware; using SecretLabs.NETMF.Hardware; using SecretLabs.NETMF.Hardware.Netduino; using SecretLabs.NETMF.IO; namespace SDFileLearn {   public class Program   {   public static void Main()   {   DirectoryInfo rootDirectory = new DirectoryInfo(@"SD");   if(!Directory.Exists(@"SDNewDir"))   { DirectoryInfo xDir= Directory.CreateDirectory(@"SDNewDir");   }   if (File.Exists(@"SDTestNew.txt"))   {   Debug.Print("File Exist!");   }   else   {   Debug.Print("Not Exist,Create New!");   }   StreamWriter xWrite = new StreamWriter(System.IO.File.Open(@"SDTestNew.txt", FileMode.Append));   xWrite.Write("Hello New Worldrn");   xWrite.Flush();   xWrite.Close();   Thread.Sleep(1000);   if (File.Exists(@"SDTestNew.txt"))   {   StreamReader xRead = new StreamReader(@"SDTestNew.txt");   Debug.Print(xRead.ReadLine());   xRead.Close();   Thread.Sleep(1000);   }   RecurseFolders(rootDirectory);   if (File.Exists(@"SDTestNew.txt"))   {   Debug.Print("File Exist!");   }   else   {   Debug.Print("Not Exist!");   }   Thread.Sleep(1000);   }   private static void RecurseFolders(DirectoryInfo directory)   {   if (directory.Exists)   {   Debug.Print(directory.FullName);   foreach (FileInfo file in directory.GetFiles())   {   Debug.Print(file.FullName);   }   foreach (DirectoryInfo subDirectory in directory.GetDirectories())   {   RecurseFolders(subDirectory);   }   }   }   } }
#2 Bi Qin
Bi Qin
  • 23 posts
Posted 21 May 2013 - 01:24 AM
BTW,here below is my firmware information:
SolutionReleaseInfo.solutionVendorInfo: Netduino Plus 2 (v4.2.2.2) by Secret Labs LLC SoftwareVersion.BuildDate:   Jan 26 2013 SoftwareVersion.CompilerVersion:   410894
#3 mcfd
mcfd
  • 11 posts
Posted 18 September 2013 - 06:54 AM
I have similar problem. Sometimes a newly written does not get saved. I am also using firmware v4.2.2.2 on Netduino Plus 2.
Hello everyone.
Also tagged with one or more of these keywords: SD, NP2+, FileSystem
