Mini Pin Enumeration?
Best Answer NooM, 19 May 2013 - 10:03 AM
cpu.pins. is only the hardware pin enumeration. means: pin 1 there is pin1 on the _uC_
you need to use Pins.yourpin (without cpu)
#1 baxter
baxter
  • 415 posts
Posted 19 May 2013 - 09:53 AM
The following post #6 lists the enum for Mini pins as 5 through 20.
http://forums.netdui...-pin-functions/
In Object Browser, SecretLabs.NETMF.Hardware.NetduinoMini.Pins gives
the same enumeration. On the other hand, Microsoft.SPOT.Hardware.CPU.Pin
gives GPIO_Pin0 through GPIO_Pin15, as does IntelliSense. If I want to declare
pin/leg 20 as a chip select pin for SPI, how do I declare it?  This does not work for pin 20,
Dim ChipSelect As Cpu.Pin = Cpu.Pin.GPIO_Pin20 <-- ERROR
nor does this,
Dim ChipSelect1 As SecretLabs.NETMF.Hardware.NetduinoMini.Pins = Cpu.Pin.GPIO_PIN_20
The latter gives the error: GPIO_PIN_20 is not a member of Microsoft.SPOT.Hardware.CPU.Pin
I am using firmare v4.2.0.1. Also, what is GPIO_Pin0? I was using GPIO_PIN8 under the
assumption that it referred to physical leg 8, but I get no signal on Saleae Logic.
#2 NooM
NooM
  • 490 posts
  • LocationAustria
Posted 19 May 2013 - 10:03 AM   Best Answer
#3 baxter
baxter
  • 415 posts
Posted 19 May 2013 - 07:57 PM
Thanks NooM,
Works now,
Dim ChipSelect As Cpu.Pin = Pins.GPIO_PIN_8
#4 NooM
NooM
  • 490 posts
  • LocationAustria
Posted 19 May 2013 - 07:59 PM
great :D
