multi threading problem
#1 JeroenG
JeroenG
  • 13 posts
Posted 13 May 2013 - 05:04 PM
Hi
I use netduino plus
Which I/O pins are compatible for multi threading.
I have a problem with multithreading.
Code:
Imports Microsoft.SPOT
Imports SecretLabs.NETMF.Hardware.NetduinoPlus
Module Module1
Dim button As New InputPort(Pins.ONBOARD_SW1, False, Port.ResistorMode.Disabled)
Dim Sensor As New InputPort(Pins.GPIO_PIN_D0, False, Port.ResistorMode.Disabled)
Dim Motor As New OutputPort(Pins.GPIO_PIN_D1, False)
Dim StepMotor As New OutputPort(Pins.GPIO_PIN_D2, False)
Dim tMotor As New Thread(AddressOf RotateMotor)
Dim tStepMotor As New Thread(AddressOf RotateStepMotor)
Sub Main()
' write your code here
tMotor.Start()
tStepMotor.Start()
Do
Loop
End Sub
Sub RotateMotor()
If button.Read = True Then
Do
Motor.Write(True)
Thread.Sleep(1)
Motor.Write(False)
Thread.Sleep(63)
Loop Until buton.Read = False
End If
End Sub
Sub RotateStepMotor()
If Sensor.Read = True Then
Do
StepMotor.Write(True)
Thread.Sleep(20)
StepMotor.Write(False)
Thread.Sleep(20)
Loop Until Sensor.Read = False
End If
End Sub
End Module
[color=rgb(0,0,0);]If sensor is active then all is OK.[/color]
[color=rgb(0,0,0);]If button is active then all is OK.[/color]
[color=rgb(0,0,0);] [/color]
[color=rgb(0,0,0);]If button and sensor are active then everything is not OK.[/color]
The output signal of Motor is the same as the output signal of Stepmotor.
What is wrong?
#2 hanzibal
hanzibal
  • 1287 posts
  • LocationSweden
Posted 13 May 2013 - 06:57 PM
Hi! Start by removing the do...loop in Sub Main, instead use Thread.Sleep(Timeout.Infinite). Next, both your threads will exit as soon as sensor and button reads true respectively. Once a thread exits its method, it stops running and won't get called again per se. Therefore, replace the "loop untill..." with just "loop" in each of the corresponding methods and it should work better. Better still would be for you to declare both sensor and button as Interrupt ports and then use the interrupt to turn motor rotation on and off depending the edge being high or low.
#3 JeroenG
JeroenG
  • 13 posts
Posted 13 May 2013 - 07:10 PM
I will try tomorrow.
#4 hanzibal
hanzibal
  • 1287 posts
  • LocationSweden
Posted 13 May 2013 - 09:48 PM
I forgot to say earlier; move the if block to inside the do...loop for both threads.
