Directory creation woes
SD directory
5 replies to this topic
#1 Verdris
Verdris
  • 128 posts
  • LocationReno, NV
Posted 01 May 2013 - 11:33 PM
Hi all. I have this snip of code:
if (Directory.Exists(@"SD"))            {                green.Write(true);                red.Write(true);                //Directory.SetCurrentDirectory(@"SD");                Directory.CreateDirectory(@"SDone");                Thread.Sleep(1);                Directory.CreateDirectory(@"SDtwo");                Thread.Sleep(1);                Directory.CreateDirectory(@"SDthree");                Thread.Sleep(1);                Directory.CreateDirectory(@"SDfour");                Thread.Sleep(1);                Directory.CreateDirectory(@"SDfive");                Thread.Sleep(1);                Directory.CreateDirectory(@"SDsix");                Thread.Sleep(1);                foreach (string dir in Directory.GetDirectories(@"SD"))                {                    Debug.Print("I found: " + dir);                }                Thread.Sleep(100);                green.Write(false);                red.Write(false);            }
The debug output is:
I found: SDoneI found: SDtwoI found: SDthreeI found: SDfourI found: SDfiveI found: SDsix
But when I put the SD card in my computer, SDsix doesn't exist. What's going on?
#2 taylorza
taylorza
Posted 02 May 2013 - 12:15 AM
Have you unmounted the file system before removing the SD card and putting it in your computer?
#3 NooM
NooM
  • 490 posts
  • LocationAustria
Posted 02 May 2013 - 01:25 AM
i guess it has something todo with buffering or stuff like that.
i had dataloss when i didnt unmount the sd card before shutting down the netduino/ remove the sd card.
so i made a button to unmount it, and everything was fine (except it sucked ...)
#4 Verdris
Verdris
  • 128 posts
  • LocationReno, NV
Posted 02 May 2013 - 01:45 AM
I use feedback LEDs to indicate when the filestreams are disposed. I'm not getting data corruption, It's just not making directories.
And when it does, I can't create a file inside the directory.
#5 cutlass
cutlass
  • 78 posts
  • LocationNew England. :)
Posted 02 May 2013 - 04:38 AM
Is there a "Flush()" subroutine in the netmf?
http://msdn.microsof...ream.flush.aspx
Namespace:  System.IO
C#
public abstract void Flush()
#6 Verdris
Verdris
  • 128 posts
  • LocationReno, NV
Posted 02 May 2013 - 08:45 PM
C#
I'm not using any streams.
Also tagged with one or more of these keywords: SD, directory
