Serial can't use ReadLine();
serial c#
6 replies to this topic
#1 Wayneio
Wayneio
  • 24 posts
Posted 25 April 2013 - 09:14 PM
I'm starting to have a bit more luck with the netduino and VS2012, but have hit an annoying point in my code.
I am using serial.ReadLine(); to read data sent back from the netduino to the pc, but I now need the netduino to also read the information, however I get the error "System.IO.Ports.SerialPort' does not contain a definition for 'ReadLine' and no extension method 'ReadLine' accepting a first argument of type 'System.IO.Ports.SerialPort' could be found (are you missing a using directive or an assembly reference?)"
Now I can't understand why, as the code on the netduino for serial communication is virtually identical to that of the code on the pc-side applicaiton, and that works fine.
This is a seciton of the code that has the error in it
	 static void serial_DataReceived(object sender, SerialDataReceivedEventArgs e)	    {		    // create a single byte array		    byte[] bytes = new byte[1];		    // as long as there is data waiting to be read		    while (serial.BytesToRead > 0)		    {			   theLED.Write(true);			   Thread.Sleep(500);			    // read a single byte			   serial.Read(bytes, 0, bytes.Length);               // the bit that doesn't work...			   theText = serial.ReadLine();			   // send the same byte back			   serial.Write(bytes, 0, bytes.Length);			    theLED.Write(false);		    }
#2 ziggurat29
ziggurat29
  • 244 posts
Posted 26 April 2013 - 12:35 AM
well, ok you won't like this explanation, but... SerialPort does not have a method called ReadLine()!  Remember that NETMF is a subset of the 'full' subset you get on the desktop.  There's loads of things that are not there; you have code up that functionality from the basic things that are there.
#3 GrZeCh
GrZeCh
  • 29 posts
  • LocationPoland
Posted 26 April 2013 - 06:51 AM
Maybe this will help you:
http://forums.netdui...rt-code-review/
#4 Wayneio
Wayneio
  • 24 posts
Posted 26 April 2013 - 08:17 PM
Thanks for the replys, I have got the applciation working without ReadLine functionality now (after fianlly giving up with MF 4.3 and VS2012, resorting to another computer with VS2012).
#5 Wayneio
Wayneio
  • 24 posts
Posted 26 April 2013 - 09:10 PM
Just another related question, i have read the command, and then the amount of times that the command should be executed. When i run this code and step through it with visual studio, the LED flashes as I would expect, but if I run it with no breakpoints, the LED stays on constantly.
I guess this is something to do with the speed that it all happens without breakpoints. Can anyone shed any light?
//flash by set amount					    int cnt = 0;					    while (cnt < CMDNo)					    {						    theExLED.Write(true);						    Thread.Sleep(5000);						    theExLED.Write(false);						    cnt++;					    }
#6 ziggurat29
ziggurat29
  • 244 posts
Posted 26 April 2013 - 10:50 PM
yes, the while loop immediately turns the led on after it has turned it off.  If you want it to take 5 sec per cycle (as you have coded it), break the 5 sec into two delays of 2.5 sec, and put one after when you turn on, and one after when you turn off.  e.g.
//flash by set amountint cnt = 0;while (cnt < CMDNo){	theExLED.Write(true);	Thread.Sleep(2500);	theExLED.Write(false);	Thread.Sleep(2500);	cnt++;}
#7 Wayneio
Wayneio
  • 24 posts
Posted 27 April 2013 - 08:11 AM
Oh god. Now i feel daft. I'll make the excuse that it was late at night when i was trying this. Thanks :)
