implementing serial communication for netduino plus 2
netmf c# rs232 netduino plus 2
  • This topic is locked This topic is locked
1 reply to this topic
#1 m.sainath
m.sainath
  • 7 posts
Posted 21 April 2013 - 12:34 PM
using System;using System.Net;using System.Net.Sockets;using System.Threading;using System.IO.Ports;using System.IO.Ports.SerialPort;using Microsoft.SPOT;using Microsoft.SPOT.Hardware;using SecretLabs.NETMF.Hardware;using SecretLabs.NETMF.Hardware.Netduino;namespace Microsoft.SPOT.Hardware{     public sealed class SerialPort : IDisposable         {                 public SerialPort(SerialPort.Configuration config);         public SerialPort.Configuration Config { get; set; }         public void Dispose();                 public void Flush();                 public int Read(byte[] buffer, int offset, int count, int timeout);                 public int Write(byte[] buffer, int offset, int count);                  public enum BaudRate                    {                            Baud4800 = 4800,                            Baud9600 = 9600,                            Baud19200 = 19200,                            Baud38400 = 38400,                            Baud57600 = 57600,                            Baud115200 = 115200,                            Baud230400 = 230400,                    }        public enum Serial                    {                            COM1 = 0,                            COM2 = 1,                            COM3 = 2,                            COM4 = 3,                    }        public class Configuration                    {                            public readonly SerialPort.Serial Com;                            public readonly bool FlowControl;                            public readonly SerialPort.BaudRate Speed;                public Configuration(SerialPort.Serial com, SerialPort.BaudRate speed,                                 bool flowControl);                    }         } }namespace BarcodeScanner{    public class Program    {        public static void Main()        {            // write your code here            Microsoft.SPOT.Hardware.SerialPort.Configuration config = new Microsoft.SPOT.Hardware.SerialPort.Configuration(Microsoft.SPOT.Hardware.SerialPort.Serial.COM1, Microsoft.SPOT.Hardware.SerialPort.BaudRate.Baud9600, false);            Microsoft.SPOT.Hardware.SerialPort serialPort = new Microsoft.SPOT.Hardware.SerialPort(config);                        byte[] outBuffer = System.Text.Encoding.UTF8.GetBytes("Hello World!rn");            serialPort.Write(outBuffer, 0, outBuffer.Length);                        serialPort.Dispose();            //keeps the emulator running to see results                        Thread.Sleep(Timeout.Infinite);        }    }}
This is the code i'm using to achieve serial communication for a netduino plus 2 based on .NET micro framework. When i do i get a error message stating that "A using namespace directive can only be applied to namespaces; 'System.IO.Ports.SerialPort' is a type not a namespace ". Upon seeing this i comment out the line of code
then I encounter couple of error messages stating that "'Microsoft.SPOT.Hardware.SerialPort.Configuration.Configuration(Microsoft.SPOT.Hardware.SerialPort.Serial, Microsoft.SPOT.Hardware.SerialPort.BaudRate, bool)' must declare a body because it is not marked abstract, extern, or partial"
Please help me resolve this issue as soon as possible. The scenario i'm working on is to get data from a barcode scanner via a rs232 cable connected to a breakout board which converts rs232 to serial. Thanks in advance.
#2 Stefan
Stefan
    Moderator
  • 1965 posts
Posted 21 April 2013 - 06:13 PM
posted twice; http://forums.netdui...etduino-plus-2/
