LCD Help needed, 16x2s are boring
#81
Posted 19 May 2011 - 01:07 PM
If you look at the first page of this thread, on the 7th post or so at the bottom it says:
"Notes: "NokiaCharacters.ASCII" is a public static class that contains the "public static byte[] ASCII = new byte[] {....};" thing. "
Basically take the byte array called ASCII from the 5th post on the first page and put it in its own class called NokiaCharacters.
Alternatively you could put the byte array right into your code.
Hope that helps,
Mike
#82
Posted 19 May 2011 - 05:14 PM
the display is 84x84 pixels, so each character needs to be defined by a bitmap telling which bits are on and off for a given character. Here is a little background if you are interested: http://www.instructa...g-a-custom-font
Hope that helps,
Mike
Mike & All ...
Thanks so much for the help. Everything works!
Now on to get to email working.
#83
Posted 19 May 2011 - 07:03 PM
Mike & All ...
try lowering your contrast. it will look nicer
#84
Posted 12 July 2011 - 09:57 PM
#85
Posted 13 July 2011 - 08:29 AM
I have exactly the same LCD, if you're patient, I shall try it later this week and post a breadboard-view on the wiki and PM you when it's done.Hello, I do not understand electronics and I’m starting with the development for netduino, I would like to know if you could tell me how to connect the LCD Nokia 5110 on the netduino with this breadboard.
#86
Posted 13 July 2011 - 12:58 PM
#87
Posted 14 July 2011 - 08:50 PM
I'm going to make a wiki about it, but I used:Hello Stefan, thanks again for the help, I'll wait then.
- NETMF Code (and help) from Omar
- Help from Steven (bitmap part on PC)
I can convert JPEG's, GIF's, etc. to a format that can be displayed on the display. Also, Omar's text-functions work superb.
When the wiki page is completed, I shall post again. (won't be today, needs some rest)
#88
Posted 14 July 2011 - 10:07 PM
#89
Posted 15 July 2011 - 04:11 PM
- Riny likes this
#90
Posted 16 July 2011 - 05:26 PM
#91
Posted 16 July 2011 - 05:48 PM
The image gives a 404 here?Thanks again, and sorry for the quality of the image.
#92
Posted 18 July 2011 - 11:44 AM
My fault, now is ok.
#93
Posted 18 July 2011 - 11:55 AM
woah! that backlight is bright!My fault, now is ok.
#94
Posted 18 July 2011 - 12:09 PM
#95
Posted 18 July 2011 - 12:59 PM
*** OFF TOPIC ***
Eduardo, what it means your signature?...I understand only "The heart..."
Sound interesting!
Hello Mario,
It is one of the most famous quotes by Blaise Pascal (Pensées book), I think in English would be something like
"The heart has reasons that reason cannot know."
#96
Posted 18 July 2011 - 01:26 PM
Very beautiful, and so very true"The heart has reasons that reason cannot know."
#97
Posted 19 July 2011 - 04:24 AM
After trying to open the project it insinuated that I needed to upgrade to the 4.2 beta SDK and firmware, after upgrading I get the below output saying I need 4.1 again, I assume I can edit some files to fix? I am trying to find it now, not sure what I am doing, thanks for the help.
Resolving. Link failure: some assembly references cannot be resolved!! Assembly: SecretLabs.NETMF.Hardware.NetduinoPlus (4.1.0.0) needs assembly 'Microsoft.SPOT.Hardware' (4.1.2821.0) Assembly: SecretLabs.NETMF.Hardware.NetduinoPlus (4.1.0.0) needs assembly 'mscorlib' (4.1.2821.0) Assembly: SecretLabs.NETMF.Hardware (4.1.0.0) needs assembly 'mscorlib' (4.1.2821.0) Assembly: SecretLabs.NETMF.Hardware (4.1.0.0) needs assembly 'Microsoft.SPOT.Hardware' (4.1.2821.0) Assembly: Nokia 5100 LCD (1.0.0.0) needs assembly 'SecretLabs.NETMF.Hardware' (4.1.0.0) Assembly: Nokia 5100 LCD (1.0.0.0) needs assembly 'Microsoft.SPOT.Hardware' (4.1.2821.0) Error: a3000000 Waiting for debug commands... The program '[1] Micro Framework application: Managed' has exited with code 0 (0x0).
#98
Posted 19 July 2011 - 06:38 AM
HiStefan, I downloaded the project from the wiki page Nokia 3310 LCD
I just seen that the code for the LCD indeed has 4.2 as Target Framework Version. The version needs to be correct at 3 points:
- Visual Studio (can be changed, so you actually don't need to change firmware); go to the project's properties and modify the target framework.
- Software Development Kit (If you install the 4.2 SDK, it will also install the 4.1 SDK)
- Netduino Firmware (see http://wiki.netduino...ep-by-step.ashx for guidelines)
Updating the netduino to 4.2 doesn't need to be done. Which firmware do you currently have in your Netduino? You can find that out by starting MFDeploy.exe (at default installed at "C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.1\Tools"), select USB->Netduino and click Target->Device Capabilities. This is an example of the firmware version:
SolutionReleaseInfo.solutionVendorInfo: Netduino (v4.2.0.0 b1) by Secret Labs LLC
#99
Posted 20 July 2011 - 03:46 AM
...-go to the project's properties and modify the target framework.
...- Netduino Firmware (see http://wiki.netduino...ep-by-step.ashx for guidelines)
Well, after setting the target framework in the .csproj to 4.1 and spending about three hours trying to revert my bricked Netduino+ firmware back to 4.1.1.0 after my botched attempt to upgrade it to 4.2, finally got it to work, thanks!
I love these little GLCD screens, will post if I make anything interesting.
#100
Posted 20 August 2011 - 05:16 AM
I've played a little with the code and found that we can't use text functions together with graphics - the text goes directly to the LCD than the graphic gets into the buffer first and than whole buffer transferred to display.
So I added functions DrawString and DrawChar that draw string into buffer first, so it can be combined with graphics and shown by calling Lcd.Refresh() function:
public void DrawString(int x, int line, string str, bool mode) { foreach (char c in str) { DrawCharacter(x, line, c,mode); x += 5; // 6 pixels wide if (x + 5 >= 84) { x = 0; // ran out of this line line++; } if (line >= 48 / 8) { return; // ran out of space :( } } } protected void DrawCharacter(int x, int line, char c, bool mode) { for (int i = 0; i < 5; i++) { if (mode) ByteMap[x + (line * 84)+ i] |= NokiaCharacters.ASCII[c - 0x20][i]; else ByteMap[x + (line * 84) + i] |=(byte) ~NokiaCharacters.ASCII[c - 0x20][i]; //x++; } }
Eugene
