LCD Help needed, 16x2s are boring
#21
Posted 31 December 2010 - 12:38 PM
#22
Posted 31 December 2010 - 12:58 PM
If anyone wants this one, I'll mail it to you for FREE, with the proviso that you'll experiment with it and share your experiences here.
If you're serious, I'll take you up on that - with the added proviso that if I can't get it to work, I'll make the same offer
Do you have any idea what the problem is?
#23
Posted 31 December 2010 - 01:51 PM
I'm completely serious. Add "@gmail.com" to my username and send me your preferred mailing address. It will be sent first class mail. I have no idea what the problem is, but I do not think that the device is broken. FYI: The device is quite small about 1.5 inches x 1.5 inches (the size of an old school cell phone screen) so it will easily fit in a standard envelope.If you're serious, I'll take you up on that - with the added proviso that if I can't get it to work, I'll make the same offer
Good luck!
P.S. I think we could (re)start a tradition here of passing around unwanted/surplus small components in first class envelopes. I have successfully sent and received parts this way years ago (1980's) and would like to return to this old pasttime.
#24
Posted 31 December 2010 - 04:45 PM
#25
Posted 31 December 2010 - 05:29 PM
What sort of things will you try? I tried stock SPI, bit-banged SPI, carefully managing the SCE (i.e. latch) line relative to SCLK, carefully managing the RST line relative to SCE, carefully managing D/C relative to MOSI, all the various commands (such as clear screen, inverse video, etc.) but I could not get the display to blink.And both of us can't get it to work so, I'll keep trying, I am still waiting for sparkfun to email me back.
#26
Posted 31 December 2010 - 05:59 PM
I am not sure what to try, I am just reading the datasheet again. I just haven't giving up on it, I really like this little screen.
#27
Posted 02 January 2011 - 05:08 PM
If you have an Arduino lying about, test the display out with that first (I have both the Arduino and NetDuino).
This has helped me out in the past in identifying what the issue is, or at least confirming that my assumptions on setup and wiring are correct.
This should also eliminate the possibility that the display is broken (or otherwise
If you haven't been taken up on your offer I'd be interested to have a look
-(e)
#28
Posted 02 January 2011 - 05:45 PM
I peronally think this is a fantastic idea and would gladly take part. As I'm very new to the netduino and haven't built circuits in years (I'm currently arranging to get my oscilloscope out of storage) it may take me a couple of months before I've got anything worth passing on - But I'd happily do so then
#29
Posted 04 January 2011 - 03:36 AM
I really liked your suggestion, so I went out an bought an Arduino UNO.Hi,
This should also eliminate the possibility that the display is broken (or otherwise)
-(e)
And while I kinda like the Arduino (I never used one before), I still cannot get this little LCD screen to display anything (using the example code from SparkFun and the same pins that they specify.)
#30
Posted 04 January 2011 - 03:48 AM
12 minutes later.....I really liked your suggestion, so I went out an bought an Arduino UNO.
HEY OMAR! I got it working with the Arduino! The second example on the SparkFun site works on the Arduino straight away.
I think our wiring is correct, but something else must be wrong. I'll figure it out tonight on the Saleae and port the solution to the Netduino.
#31
Posted 04 January 2011 - 04:21 AM
OMAR! I got it working on the Netduino! This seems to be the key section, I didn't change much else...
private static void LcdInitialize() { ResetPort.Write(false); ResetPort.Write(true); LcdWrite(Command, 0x21); // LCD Extended Commands. LcdWrite(Command, 0xBf); // Set LCD Vop (Contrast). //B1 LcdWrite(Command, 0x04); // Set Temp coefficent. //0x04 LcdWrite(Command, 0x14); // LCD bias mode 1:48. //0x13 LcdWrite(Command, 0x0C); // LCD in normal mode. 0x0d for inverse LcdWrite(Command, 0x20); LcdWrite(Command, 0x0C); }
[Like Mike Iaconelli says...NEVER GIVE UP!]
#32
Posted 04 January 2011 - 04:50 AM
OMAR! It works with either bit-banged SPI or with built-in SPI. The key is the startup sequence.
Procedure chipInitialize = delegate { try { resetPort.Write(false); resetPort.Write(true); chipMode(Command); spi.Write(new byte[] {0x21, 0xBF, 0x04, 0x14, 0x0C, 0x20, 0x0C}); } finally { chipMode(Data); } };
#33
Posted 04 January 2011 - 04:55 AM
Edited by AlfredBr, 05 January 2011 - 09:39 AM.
#34
Posted 04 January 2011 - 05:13 AM
#35
Posted 04 January 2011 - 01:20 PM
Wait, did you literally go out somewhere and buy an Arduino? Like, to a bricks and mortar store? Where are these stores???
Besides that, thank you for your work on this. I was just about set on this screen: http://www.sparkfun.com/products/10090
...which I might still get, but now having a <$10 option is fantastic.
#36
Posted 04 January 2011 - 07:45 PM
I got the Arduino from Amazon.com, not from a retail store.
I guess I should apologize to Basiclife, since I got this working I guess I won't be giving it away. But I do have some other useful components that I'll offer up in a future post.
#37
Posted 04 January 2011 - 08:02 PM
No apologies needed - and congratulations on getting it working
#38
Posted 04 January 2011 - 08:49 PM
That is really interesting... let me try that....
WOW! NICE! I thought that the initializing stuff could be wrong and tried sending the bytes shown on the data sheet example but taht didn't do it. Sir you are amazing, now I can actually show live data with my netduino plus!!!! I am so happy, I can't wait till I am done with my exams (studying now, no time to play
#39
Posted 04 January 2011 - 09:31 PM
Let me know when you get yours online! I'll try to test the limits of the transfer speed and play with uploading bitmaps tonight.That is really interesting... let me try that....
WOW! NICE! I thought that the initializing stuff could be wrong and tried sending the bytes shown on the data sheet example but taht didn't do it. Sir you are amazing, now I can actually show live data with my netduino plus!!!! I am so happy, I can't wait till I am done with my exams (studying now, no time to play). Thanks a lot! Whooooo
awesome!
#40
Posted 04 January 2011 - 09:57 PM
Oh it works! I am playing with it right now, trying to make: SetPixel(int x, int y, bool on) and Write(bool[][] grid).... it will take a long time though, I want to figure out how to move the cursor so I can write on certain parts of it and not others. Maybe it isn't possible, but I am reading that datasheet again!Let me know when you get yours online! I'll try to test the limits of the transfer speed and play with uploading bitmaps tonight.
