GPRS Shield - Netduino Plus 2 (and Netduino Plus 1) - Netduino Forums
GPRS Shield
#1 yetanothernetduino
yetanothernetduino
  • 7 posts
Posted 04 April 2013 - 01:21 PM
I am using this code
http://netduino2seedgsm.codeplex.com/
and this hardware
http://www.seeedstud...l?cPath=132_134
Managed to send sms ok however reading all SMS have been no joy.
Just wondering y whthe visual studio output produces funny characters: eg AÕi5GªA,j etc etc even thought the code is converted byte[] from utf8 string.
  private static string GetUTF8StringFrombytes(byte[] byteVal)
  byte[] btOne = new byte[1];
  StringBuilder sb = new StringBuilder("");
  char uniChar;
  for (int i = 0; i < byteVal.Length; i++)
  btOne[0] = byteVal[i];
  if (btOne[0] > 127)
  uniChar = Convert.ToChar(btOne[0]);
  sb.Append(uniChar);
  Debug.Print(uniChar.ToString());
  else
  sb.Append(new string(Encoding.UTF8.GetChars(btOne)));
  Debug.Print(new string(Encoding.UTF8.GetChars(btOne)));
  return sb.ToString();
#2 j2inet
j2inet
  • 11 posts
Posted 05 April 2013 - 03:59 PM
and this hardware
Have you taken a look at the byte stream that has come back to verify that the problem isn't in the data itself? The range of the byte values you get back should be between 0x20(32) and 0x7E (126~) if you are getting back plain english text. If you see your values are outside this range then the problem isn't with your conversion, it's with the data itself.
#3 yetanothernetduino
yetanothernetduino
  • 7 posts
Posted 21 April 2013 - 01:57 PM
Even if the data is in in that format, is the a conversion out there?
Because it's kind of useless to read sms that are unreadable to human.
I am sure someone out there would having this kind of this issue?
#4 ziggurat29
ziggurat29
  • 244 posts
Posted 21 April 2013 - 03:02 PM
its not clear to me why you need to do all the work you are doing in:
  private static string GetUTF8StringFrombytes(byte[] byteVal){}
I think any call to that can be replaced simply with:
  new string(Encoding.UTF8.GetChars(byteVal)
That being said, be aware that Encoding.UTF8.GetChars() will throw if the bytes are not valid UTF.  This can easily happen if what you are getting back is garbage to begin with, so use a try block if you care about robustness.
I have used the SIM900-based module successfully, though I do not use it for SMS, so I can't give advice on that feature.
