Best Answer MarcinG, 14 April 2013 - 06:56 PM
Ok,
The problem was Advanced USB Monitor and it's filter driver. After uninstall everything back to normal.
![]() NP2 not responding
Started by MarcinG, Mar 29 2013 10:07 PM
![]() Best Answer MarcinG, 14 April 2013 - 06:56 PM
Ok,
The problem was Advanced USB Monitor and it's filter driver. After uninstall everything back to normal. Go to the full post![]()
10 replies to this topic
Posted 29 March 2013 - 10:07 PM Hi, NP2 is visible in MFDeploy but I can't ping, erase, set network ... anything. I can't deploy any app. I tried: - upgrading to 4.3 SDK (with uninstall all previous versions) - re-flashing like 3 times to latest 4.3 firmware Until today I was using NP1 without any problems. I'm using W7 64bit. What can I check or do with it ??
-- Marcin
Posted 30 March 2013 - 04:09 PM
Hi Marcin,
Was NP2 working with NETMF 4.2? Using the .NET MF 4.2 QFE2 and Netduino 4.2 SDKs?
The NETMF 4.3 firmware is still beta; we're appreciate the opportunity to help figure out what's going on with the 4.3 beta firmware to make sure that the official 4.3 release is high-quality...but it's probably best to make sure we're working with NETMF 4.2 first.
Sorry for the troubles; let's see if we can get you up and running here.
BTW, welcome to the community. I'm guessing that you've been lurking for a while; thanks for posting and joining in on the conversation!
Posted 03 April 2013 - 12:27 PM Hi Chris,
Thank's for reply.
No - it didn't work on 4.2. So I decided to reflash firmware 4.2 and after that I upgraded to 4.3. All the steps of reflashing/upgrading ended with "success " message.
Is it possible that board/stm is broken but somehow it passes reflashing without problems??
Posted 04 April 2013 - 08:31 PM
I've been experiencing a similar problem over the last few days. In my case it seems if an unhandled exception happens early in the program than the board halts and I can't deploy anything to it. After that I have to reflash since resetting doesn't seem to work. I speculate that on a reset it's starting off running my program and halting before I can do another redeployment.
During development I've found it helpful to put a 4 second delay at the start of my program (via Thread.Sleep). When the board is halted I can at least reset it and have 4 seconds to get a deployment going before the problem code executes.
Posted 05 April 2013 - 03:52 AM Same thing happening for me, Im having to reflash the board anytime I hit an unhandled exception.
Posted 09 April 2013 - 01:26 PM But in my case I can't deploy anything, even after reflashing. I think that somehow the board it's broken and I'll send it for replacement. Or maybe some other ideas how to bring it alive??
Posted 11 April 2013 - 02:36 AM
Hi MarcinG,
Be sure to _erase_ your board using STDFU Tester before reflashing it with DFUSE.
Otherwise you're just overwriting NETMF and not your application--and the board will immediately try to boot your app (which is presumably where the crash scenario begins) and blocking MFDeploy.
Posted 11 April 2013 - 05:53 PM I've done that. It's driving me crazy!
I've checked that if I erase in DFUTester and then upload there are FF's in Internal Flash. After reflashing in DFUSE and then upload in DFUTester there is someting in Internal Flash - so reflashing works. What should I have in: Option Bytes, OTP Memory and Device Feature??
Maybe someone can send me some test file(blinking led or somethig) file (in hex maybe), please.
Posted 11 April 2013 - 06:29 PM Ok,
There is something wrong with my PC. On another laptop I can deploy app. Strange is that I can deploy for NP1 but not for NP2. Thanks for all help.
Posted 14 April 2013 - 06:56 PM Best Answer Ok,
Posted 18 April 2013 - 12:24 AM LOL, Thanks for the tip. I managed to slide my debug in before it ran my app w/unhandled exception. It took a couple tries, but perfectly timing VS Deploy solution with the Netduino reset button saved me some time from reflashing. Lance McCarthy Microsoft MVP (Windows Platform Development) 1 user(s) are reading this topic0 members, 1 guests, 0 anonymous users | ||||||||||||||
