What happened to the Bit Shift Operators?
bit shift operators vb
10 replies to this topic
#1 clefranc
clefranc
  • 16 posts
Posted 07 March 2013 - 09:47 PM
What happened to the Bit Shift Operators in VB?
These operators works in C#, but I can't use them in VB?
EDIT#1: I'm using N+2 4.3
EDIT#2: You can use multiply and divide for the bit shift like this
UShort * 2^8 for left shifting 8 bit (<< 8)
UShort / 2^8 for right shifting 8 bit (>> 8)
#2 JoopC
JoopC
  • 148 posts
Posted 08 March 2013 - 10:10 AM
Ridiculous as bit shifting is no longer supported. Then it is houtje touwtje Visual Basic.
#3 hanzibal
hanzibal
  • 1287 posts
  • LocationSweden
Posted 08 March 2013 - 02:05 PM
Have those ever been available in VB?
In C# I sometimes miss the ROL and ROR from assembler.
Btw, is there a way to do bitwise INV, OR and AND in VB?
// C# to mask off bit 7 from variable aa &= ~0x80;
What does "houtje touwtje" mean, is it dutch for "humty dumty"?
#4 baxter
baxter
  • 415 posts
Posted 08 March 2013 - 06:27 PM
Yes, and they are still there in 4.2.
Dim MyInteger As Integer = 12345678Dim final As IntegerDim Shifted As IntegerShifted = MyInteger << 4final = Shifted >> 4 '------> 12345678final <<= 4final >>= 4 ' -------> 12345678Dim x As Integerx = 3 And 5 ' -------> 1x = 5 Or 3  ' -------> 7
#5 hanzibal
hanzibal
  • 1287 posts
  • LocationSweden
Posted 09 March 2013 - 01:38 AM
Oh nice, I wasn't aware of that
#6 Woodlands-Glen
Woodlands-Glen
  • 16 posts
Posted 27 January 2014 - 10:36 PM
VB has bit shift capabilities.  Will they be put back in?  I have read in other posts that it is not in 4.2 and VS 2012 and I am using 4.3 experimental with VS2013 and it still isn't there.
Glen
#7 Chris Walker
Posted 31 January 2014 - 03:44 AM
Hi Glen, Can you please file a bug report on this over at netmf.codeplex.com? I'm not sure if bit-shifting is part of VBCore or not, but if it is then this sounds like a compiler issue. In the meantime...can you use multiplication and division instead in your application? For instance, multiply your value by "2 to the power of x" instead of bit-shifting left by x. Chris
#8 Woodlands-Glen
Woodlands-Glen
  • 16 posts
Posted 01 February 2014 - 07:14 PM
I put an issue in on the codeplex site.  Hopefully the bit shift operators will be put back in.
Glen
#9 GDSever
GDSever
  • 81 posts
  • LocationNewark, DE
Posted 02 February 2014 - 06:06 PM
Not sure it helps, but I am using a Netduino 1 running 4.2 and VS2010 and I am using bit shifter operators in my VB code without any issue.
#10 Woodlands-Glen
Woodlands-Glen
  • 16 posts
Posted 03 February 2014 - 04:06 PM
It appears to be something with 4.3.
#11 boklu
boklu
Posted 31 March 2014 - 08:33 AM
i just have the same problem with the bit shifting! Are there a sulotion now?
boris
