PWM - Deploy Fail
#1 zee
zee
  • 47 posts
Posted 07 March 2013 - 09:02 AM
This is my second time try to run this project. Its from the 'Getting Started with Netduino' on Chapter 6, Dimmer Code..I have installed the SecretLabs.NETMF.Hardware.PWM and there is no error in the code. However, when it is running, it states that "unable to communicate with device - USB:Netduino" under the output tab.
There is also a message box pop-up "There were deployment errors. Continue?".
Please help me !!! Thank you!
#2 ziggurat29
ziggurat29
  • 244 posts
Posted 07 March 2013 - 02:36 PM
I get that all the time with projects unrelated to PWM, but I always assumed it was because I run my dev env in a vmware image (and USB is always a little hinky in that case).  I unplug and plug back in, sometimes restarting VS2010 and things become stable again.
That being said, since you mention PWM, I found out myself that if you set the PWM frequency too low, you can lock up the netmf system, so don't set it too low.  Sorry, can't remember what 'too low' is; in my case I had a typo and I set it to 10 Hz, but I think 'too low' is actually something like 100 or 100 Hz.
#3 zee
zee
  • 47 posts
Posted 08 March 2013 - 12:37 AM
Hi.. Thanks for the quick reply.. I did not set any frequency on it.
Here are my codes..
using System.Net;
using System.Net.Sockets;
namespace Dimmer_PWM
            // write your code here
            SecretLabs.NETMF.Hardware.PWM led = new SecretLabs.NETMF.Hardware.PWM(Pins.GPIO_PIN_D5);
            SecretLabs.NETMF.Hardware.AnalogInput pot = new SecretLabs.NETMF.Hardware.AnalogInput(Pins.GPIO_PIN_A0);
            pot.SetRange(0, 100);
            int potValue = 0; //store and retrieve the potentiometer's current position
                //read the value of the potentiometer
                potValue = pot.Read();
                //change the led intensity base on the potentiometer's value (0-100%)
               led.SetDutyCycle((uint) potValue);
#4 Chris Walker
Posted 14 March 2013 - 06:55 PM
Hi zee, The code looks fine at first glance. Let's check out the other variables... What board are you using? Netduino? Netduino Plus 2? When you open up project properties, and then go to the .NET MF tab...do you see your Netduino in the device pulldown? When deployment fails, go to the Output tab in Visual Studio. If it shows more information about what failed during deployment, please post that info here. Chris
#5 zee
zee
  • 47 posts
Posted 15 March 2013 - 03:37 AM
Thanx for the response..
I am using Netduino Plus 2.. Yes, there is Netduino in the device pulldown..
The error in the output tab, stated "Unable to communicate with device - USB:Netduino"..
